SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
Fail lol. Both rock jock and boss 4x4 have the same results with the raptor . Back to sq 1
So it does not fit? I'm assuming since the holes don't line up for the bottom bolt. I always thought RJ had the same one for the Regular Bronco and for the BRaptor. Guess not :(. ......BUT WAIT.....is it a RAPTOR you have or a BRONCO Raptor? they are totally different vehicles. I just noticed your signature says "GEN 2" (soooo....seeing as there is no Gen 2 Bronco yet....).
rayofsi
Staten Island, NY
Raptor Gen2
bronco raptor, i also have a gen2 f150 raptor
yea the holes do not line up. looking at the arb/ome bracket, that might fit...
SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
Crummy. Must be the axle length and why Ford changed the placement of the bolt holes.
JL8jeff
Ewing, NJ
Isn't the Braptor a wider track vs the regular Bronco? Maybe that's why the rear is different. It looks like there is plenty or material to drill a new hole in the bracket though. You would probably want to make sure the bracket is at the correct angle before trying that.
Ramble_Offroad
Nels
Northern CO
2014 2D JK on 35’s
Installed the RJ relocation bracket this afternoon. I’ll take it for a spin tomorrow to see how it drives. Time will tell if the bracket contacts the frame while wheeling (Eibach Pro Truck 2.0 HD coilovers)
I’m contemplating swapping the relocation bracket for an adjustable track bar instead to avoid the frame contact possibility. Any track bar recommendations?
Rockjock / Metalcloak / Carli / etc.
Ford Bronco Rear TracBar Relocation Bracket - Get One! IMG_4805
Ford Bronco Rear TracBar Relocation Bracket - Get One! IMG_4806
Fordified1
Bob
Mid South Texas
An adjustable track bar doesn’t do the same thing as the relocation bracket which corrects the geometry. Adjustable track bar is used to center the differential, it does nothing for the geometry.
That being said, you must really have the adjusters cranked way up for your track bar to be at that much angle still. Too much lift in the front will be hard on your CV’s and steering, just an FYI.
telenerd
Laramie
Subaru
Anyone crack their track bar relocation brackets yet?
Ramble_Offroad
Nels
Northern CO
2014 2D JK on 35’s
Thanks for your reply. Yes, I’m aware (about the CVs). I’ve had the RJ relocation bracket on my bench all summer, but recently swapped my suspension from FOX coil overs to the Eibach Pro Truck 2.0 HD coils. Long story, blew up one of my FOX coils about 500 yards from the top of Engineer Pass in southern CO. I purchased the RJ relocation bracket long before I made the switch to Eibach. Hence my concern that the RJ bracket may contact the frame. My logic around swapping the relocation bracket for an adjustable track bar is that it may be my best choice without having to worry about smashing the bracket at full stuff.
Oh yes I agree, my truck is sitting high right now. These are the factory settings from Eibach and they tower above my 37’s. I plan to drive it back and forth to work a few days and then crank them down a bit. This way it may settle a bit first. 100% agreed on the CV’s.
Fordified1
Bob
Mid South Texas
Several of us have contemplated the potential frame contact which is theoretically possible, but so far I haven’t heard of anyone actually hitting the frame with the bracket. I have the Eibach 2.0’s (with regular coils) and the Rock Jock bracket myself and have done a bit of rock crawling and so far it has lifted the left tire before the right stuffs far enough to hit. High speed jumping the Bronco might be a different result IDK.
I have my rear adjusters only a couple threads from the bottom and the fronts are about the middle of the threads. (4cyl 4-dr Bronc on 35’s)
Ramble_Offroad
Nels
Northern CO
2014 2D JK on 35’s
Thanks again. Noted, no reports of bracket / frame contact yet. That’s good to hear. I’ve read similar comments to support this in B6G recently. Time will tell.
Forum fuax pas for this next part, I know this is a track bar bracket thread…it happens.
Honestly I’m surprised how much preload these Pro Truck 2.0 coils have from the factory. These are the maximums in the instructions.
Ford Bronco Rear TracBar Relocation Bracket - Get One! IMG_4627
84mm front / 148mm rear. Out of the box mine were set at 82mm front / 128mm rear. Rough measurements put my front fender flare 7” above the tire and the rear 8”.
Ford Bronco Rear TracBar Relocation Bracket - Get One! IMG_4830
My Bronco is a 2D / 37’s lots of armor plus water / aux fuel / drawer system / cooler full of beers / camping gear, etc. My Green lady is a bit of a pig.
The ability to adjust the preload in these coils (when installed) and get an HD spring kit from the factory is why I went with Eibach this time around. Hard to see because perspective is misleading but these are my CV’s sitting flat. So they definitely can come down a bit.
Ford Bronco Rear TracBar Relocation Bracket - Get One! IMG_4833
I still need to reinstall the LCA armor and source some different lower shock skids that fit the Eibach’s. I’m told that the DV8 rear shock skids fit. I also spoke to RCI today at the overland Expo. I’m hoping they can send me some measurements to guesstimate if their lower shock skids might fit. Hitting that 350 foot pound torque on the lower shock bolt was a bear, so I don’t want to do it again “twice” if I don’t have to again soon.
Jazer
Jessica
2.7 OBX
I returned my RJ bracket right after receiving it, when I realized the compressed shock length was not ideal with the Eibachs... but I've been on the fence about re-ordering lately. I experience some excessive movement I don't like under certain situations that I am curious if it will help correct. For example, when I am passing someone and crest the center high point in the road, the Bronco wiggles kind of alarmingly as it shifts it's weight. It's great in every other scenario but I am wondering if correcting the geometry in the rear will aid in reducing this strange sensation.
Might just be something to live with, with a higher center of gravity and "softer" suspension but it just feels off with this scenario.
Fordified1
Bob
Mid South Texas
I have the DV8 shock skids which do fit the Eibachs, but yes you would have to loosen the Shock bolts to put them on.
JL8jeff
Ewing, NJ
The RJ bracket helped reduce that "floating" sensation on my 2 door Sas on 37's. It sounds like you need the bracket.
Chritaka
DFW, Texas
'23 WildTrak; '06 Whippl'd Mustang (sold4upgrades)
I’ve had the RJ bracket for a while, added soon after adding my ADS setup. I’ve had some noise coming from the rear ADS coil over, which ADS thought either the upper/lower coils were out of sync or I needed an adjustable track bar. I took it to a local shop and they ordered new 350# upper coils, currently have 300# upper/400#lower coils, and AGM sliders/dividers. They said the upper coils were too compressed with my weight, but the bottoms were good. I have about 2.25” of preload in the rear. The shop disagreed that the noise was due to .25” misalignment and that the track bar would resolve. It was more likely due to the pre-load/needing a heavier spring/better divider. They did recommend Rock Krawler though for any future upgrades.
Though I was informed it wasn’t required, as I was only shifted to the driver .25” , my OCD kicked in… Rock Krawler had a nice Labor Day sale and no tax, so I snagged their adj. track bar too. It’s super stout! I can notice a slight improvement in tracking/handling over just the RJ bracket. Noise is still there, as the shop predicted. Awaiting my other parts to come in….
Pics of the adjusted RK track bar, which I believe I only tightened 1/8”, and geometry looks great:
Ford Bronco Rear TracBar Relocation Bracket - Get One! IMG_4624
Ford Bronco Rear TracBar Relocation Bracket - Get One! IMG_4625
CarmeloS
Carmelo
Central Jersey
Between installing one and dropping an inch, my girl feels like she did stock
