Question on Terraflex Track Bar relocation bracket
GA2Dr
Marietta, GA
2024 Bronco 2 DR 2.7
Hi all:
Recently had Eibach Protruck coilovers, front UCAs, and an icon adjustable track bar installed (plus alignment). I then realized I should do the relocation bracket to get my trackbar more level. My question is, if I do the install myself, would I need to have the truck aligned again? I'm thinking probably yes, but not sure.
Also, any reason why the Terraflex bracket wouldn't work with the icon bar? I am assuming that since the icon bar works with the factory setup and since the Terraflex should work with the factory bar there shouldn't be an issue, but perhaps I'm missing something. If anyone has a Terraflex bracket with a non-Terraflex track bar installed I'd love for you to chime in.
Thanks
PWillette
Parrie
Maine
Hi all:
Thanks
Did you set up the icon adjustable trac bar to match the length of the OEM bar or did a shop do the install and adjust bar length during alignment? If it was set to match the OEM bar length and your alignment was within spec you'll be fine to pop on the relocation bracket w/o additional alignment IMO. If the bar was adjusted during alignment to get you into spec I'd at least get the alignment checked after the relocation bracket install.
Should be no issue with the Terraflex bracket and Icon trac bar combo.
GA2Dr
GA2Dr
Marietta, GA
Shop did it and I do not know if they just matched the stock bar or adjusted it but they did to an alignment after everything was installed.
PWillette
Parrie
Maine
10-4. If not sure probably worth having it checked.
