Change Driveline Fluids Early!
jtgensler
Jamison
Clarion, PA
2022 Bronco, 1996 Tacoma
Anyone have experience with Amsoil ATF for the transfer case? It’s actually the fuel efficient versions that’s equivalent to Mercon LV. Just thinking I’ll add it to my order if I’m already getting the diff oil from them.
Yes. I run Amsoil fluids in my transfer case & both diffs.
Just changed all 3 after 12k miles (I run mine hard in rally events) & it was still perfect looking.
Could've easily put the same fluid back in the T-Case & FDU.
T-Case was still cherry red & looked brand new.
Front Diff fluid was still nicely colored & seemed good.
Rear diff was dark, looked like motor oil after a typical change.
I'd reccomend all 3 for the price point.
I'll likely swap to Amsoil full synthetic for my engine oil on my next change, now that I've used up all my Motorcraft I had stockpiled.
Still running Mercon for the transmission - I changed it at 75k miles & it was very good looking.
SWLABRONCO
SW Louisiana
Ford f150
I just changed the fluids in my front & rear differentials, along with the transfer case. Have about 46k on it now. Change them all around 20k. Both front and rear oil was pretty dark with both magnets covered in fine metallic material. Transfer case looked great. I used amsoil products both times. How often are most of y'all changing these items?
PWillette
Parrie
Maine
I did all of the above plus transmission at 10k then did the rear FDU again at 15k to get rid of all the wear metals from break in. I'll probably wait till 50k to do them all again.
crenca
Southern New Mexico
This is a typical finding. At 35k (both hard on and off road miles, though no towing) I have changed them once (mileage somewhere in this thread). If I wheeled more in mud/water I would have done it again by now, but I'm thinking I won't do it again till 50k...maybe my 40 or 45k oil change if I get the motivation ;)
BUCKYBRONCO2021
Long Island New York
2021 Bronco Outer Banks thats been Squatchified
Im about to hit 40k on my 21. New engine (2.7 v6 went kahblooey) so first oil change is coming up. I’m thinking of just doing them all right down the line. In my defense i got it with like 31k miles on it and it spent alot of time at the dealer or i would probably have done all the fluids then. Will reread this thread to get the deets on the right fluids. Looking to go full synthetic the whole way. Any advice is welcomed.
SWLABRONCO
SW Louisiana
Ford f150
I use amsoil products exclusively in all my vehicles, and have done so for the past 12 years. I've had really good luck with their engin oil, differential oils, and transmission fluids. I haven't had any issues with an engine, transmission, or differentials. It costs more, but I tend to keep my vehicle's for awhile.
23 bronco 2.7 46k
16 f150 5.0 90k
13 vw jetta tdi 120k
What happened to the engine in your bronco. Hope it was covered under warranty.
BUCKYBRONCO2021
23 bronco 2.7 46k
16 f150 5.0 90k
I’ve used amsoil, mobile one, and lucas in my past vehciles. Will definitely give amsoil a go in the bronco. Its good stuff. I like their gear oils.
My motor allegedly fragged during the valve recall test so it was covered. I say allegedly because there was a whole mess with how they wrote up the repair ticket. But i did get a new motor out of it.
Since i get to start fresh with the new motor i want to use good oil and filters.
SWLABRONCO
SW Louisiana
Ford f150
As far as oil filters go, I use the fram endurance
As far as oil filters go, I use the Fram Endurance (FE11955) that is sold at Walmart. I've compared it side by side with the Amsoil filter and I'm pretty sure it's the exact same filter, and it's cheaper.
23OBX2.7
AB Canada
2023 Bronco
This is depressing before and after just year or year and a half!
I guess a shitty paint job from the factory.
Warrranty just call FP up Ext 2 and send a copy pf receipt plus a pic - they will send a new one.
Thats unbeleivable.
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
Thats unbeleivable.
Parts don't carry a lifetime warranty. Owner said it's been a year and half. They can certainly try, but it should not be expected that Ford will just send a new one.
To @Bobio , there was a batch that seemed to have surface contamination prior to painting which led to the bubbling. At this point, you'll have to pull the cover and have it sandblasted and repainted. Good luck.
Nc211
Washington DC
Given how simple it is to do, I'm going to be doing it every 25k miles on mine, which should align to about once every two years. Bought the PPE transmission pan for the drain plug function, and the rear diff FP cover for same reason. Might as well use it!
Bobio
Bobby
United States
2024 Bad lands
Thanks, and I scanned over the warranty and they probably won't cover it, but like I told
23OBX2.7, I'll try.
After looking up close, it looks like it's also missing a couple of bolts..lol
Does anyone remember off-hand what size those are?
