KyTruckPlant
Goshen, Ky
05 Mustang, 05 F150, 08 Expedition EL, 23 Bronco
I'm glad I came across this thread! Thats for the education guys.
I've got 5 quarts of Valvoline 75W90 on the shelf for my boat's lower unit, I am 500 shy of 10k on the clock and I've forded it 5 or 6 times. I know what else to add to that 10k service. I Think I'll use what I have, then go to 75W140 when I run out (now that I know to change after fording).
Thanks for the PSA
Aonarch
Jack Hoff
MT
‘23 Bronco OBX 2DR Lux 2.7, ‘24 V60 Polestar
I changed mine out for really only 2 reasons...
1) I wanted to go the best Full Synth...Amsoil (at least in the Diffs)
2) I didn't trust that Ford filled them correctly.
Now that I've done it, other than maybe the t-case (because it was super easy and running LV non-synth)...I have no intention on touching my diffs again for a very long time.
100%
My Corvette's trans was WAY overfilled. When I pulled the fill plug fluid POURED out everywhere. I was not ready for it and got ATF everywhere.
JT58Bronc
JT
Fl
2022 Bronco, 1987 Chevy Squarebody 4 X 4
Re-useable gasket is on the front and rear differentials?
msujay2012
Indy
2023 Ford Bronco Wildtrak
I drained and refilled front and rear diffs and transfer case last weekend. 15k mileage. Straightforward except thought I would add the following tips:
  1. Make sure you have a good fluid transfer system to fill. The fill holes on the Bronco aren't terribly hard to get to, but you will need some good flexible hose to avoid a huge mess.
  2. Carefully pull the brake line mounts off the bolt. I used panel clip pliers, which worked really well. Not something you want to break and I doubt local dealers stock this part.
  3. Follow the tightening sequence for the torqueing the rear differential bolts. Found here.
My front diff wasn't bad, but the rear diff fluid was chocolate in color. I'm glad I did the drain/refill and used better fluids. I plan to keep the cadence at 15k-20k since I drive off-road a decent amount and it is cheap/easy maintenance.
KyTruckPlant
Goshen, Ky
I don't suppose you have a link to that same data but for the 2.3, would you?
vrtical
Doug AI
GSMNP, TN
Fords
I finished mine Sunday no problems and agree you need a pump for the transfer case. All my fluids that came out looked decent for 10k. I will say the front diff had the most on the magnet. I went with Valvoline 75W140 both diffs because I am in a warm climate so don't have to worry about sub zero temps and I wheel mine a lot so the added heavy duty is a plus.
CarbonSteel
Colorado Springs
2023 Carbonized Gray
If you use this, you will not need a pump - https://www.amazon.com/Hopkins-10106B-FloTool-Filler-Refill/dp/B000EH4UXM
The brake line clips are not available separately--they can only be purchased with the left brake line assembly which is about $80:
Part #MB3Z-2282-C > Tube Assy - Brake LH
CarbonSteel
Colorado Springs
Do you have the torque specs for the 2.3?
Rear Axle Cover Bolts = 22-25ft-lbs.
Axle & Transfer Case Fill/Drain Plugs = 22 ft-lbs.
Was it something else?
msujay2012
Indy
msujay2012
Indy
Thanks for your help. I was responding to @KyTruckPlant so not sure if he was looking for specific torque specs for the 2.3.
CarbonSteel
Colorado Springs
Thanks. I have that filler and it wouldn’t work for the diffs since the fill hole is up too high to pour down.
How's that? It worked on my Wildtrak...with the OEM and now with the Ford Performance one.
