Diffs, transfer case and transmission Fluids
contented
Karl
Central Fl
BMW M2 Competition
I want to change my drive train fluids at 66k miles. I’m struggling with finding the correct fluids for rear differential, transfer case and auto trans. I’m surprised the fluids aren’t the same for the front and rear diffs. And transfer case and auto transmission each take a different fluid.
I have a 2022 Badsquatch w/ auto trans and 4A transfer case.
Can anyone point me in the correct direction.
From owners manual -
Front diff - Gear/Transmission Fluid - SAE 80W-90. WSP-M2C197-A. No trouble finding this.
Rear Diff - Gear/Transmission Fluid - SAE 75W - 85. WSS-M2C942-A
Transfer Case - Automatic Transmission Fluid WSS-M2C938-A
Transmission - Automatic Transmission Fluid. WSS-M2C949-A
Techun
Pa
BD, 2.7, MIC, 4dr
Everyone is just going to tell you to go heavier in the rear (and the front).
jtpasto
Jerome
Salmon Idaho
2022 Bronco
I know this is not the normal place to look. Go to
www.blauparts.com
and search on the specification number. This will bring up the specific oil that meets the requirement.
Ducati1098
Ford changed the fluid for the front differential a while back. The correct fluid is now the same for front and rear.
Front and rear diff: XY-75W85-QL
Transfer case: XT-10-QLVC
Auto transmission: XT-12-QULV
Kevin Scarbel
Everglades
Kevin
Chesapeake, VA
2024 Bronco Everglades 4dr
Everglades
No struggle necessary.
Go to the Amsoil website and enter your vehicle application.
I would suggest 75w90 over the factory spec 75w85.
contented
contented
Karl
Central Fl
BMW M2 Competition
Thanks all.
