orion
Jeremy
17' F-250, 17' Explorer
There was a Starlink thread around here somewhere
That is way too expensive of a solution... 🤣
I downloaded the Google doc app but I think that that doc has to be shared in a certain way to get it.
I was mostly making a joke, but there is a way to make Google Docs offline. I've never tried it, so YMMV.
https://support.google.com/docs/answer/6388102?hl=en
Another option would be to print the doc to PDF. That may or may not turn out how you would like though.
Mustbeheresomewhere
Micah
2012 Chevrolet Silverado, 2022 Bronco Badlands 4D
I'm going to change all fluids once it warms up again. I'm at 15,000 miles. I'm wanting to try BG synco shift in my 7 MT. Transfer cases with chain drives shed a lot of metal, I've learned that over the years. It doesn't seem to bother them but I use the 4A auto more in the truck and Bronco that I have and so the transfer case gets a lot of use. I think its good idea to change it every 24K or so.
I did my tcase and both differentials at 15k - the tcase didn’t look bad (part time no 4A) but yeah - lot of metal in the differentials. Pretty much what others here have seen.
I just did my 7MT at 17k (yesterday) - oem fluid was very thin and it had a fine metallic sheen to it as well. But oem fluid is good for life right?
I hadn’t had any issues with any of the equipment to date. Hope to keep it that way
Jawaburger
Champaign, IL
2022 Bronco, 2 Door, Manual, Cactus Gray
My TC had 10mm hex heads on the drain/fill bolts. I was a little sad because my hex sockets only went up to 8mm so I had to go to the hardware store. #First_World_Problems. Fill bolt on the rear diff was just a square 3/8" though.
