Tyistick
Tyi
Pasadena
2 Dr WildTrak
Definitely would change yours @10k Especially if you have been in water deeper than the axels. In fact I would change my diffs in my Jeep after every deep water adventure
CarbonSteel
Colorado Springs
2023 Carbonized Gray
I was think about doing with my first oil change at 5k. is it better to wait in tell 15k not sure if ford put brake an oil in the diff.
There is no break-in gear oil. Ford installed standard Motorcraft 75W-85 gear oil in it.
Aonarch
Jack Hoff
MT
‘23 Bronco OBX 2DR Lux 2.7, ‘24 V60 Polestar
Yup, you should change diff fluid after each wheeling day going through water.
0ne
Nate
CO
Flex
Some conflicting information in this thread with regards to fluid type and viscosity. Am I correct that both flavors of axles/differentials use brand-of-choice in 75w-85 not 75w-140, automatic transmission uses Mercon ULV and transfer case uses Mercon LV not Mercon V? Manufacturer recommended replacement mileage is 150k for all unless severe service or water fording? 60k for automatic transmission based on fluid condition observations of a professional Ford technician?
NC_Pinz
Central NC
Proof is documented. Not sure I’d go 25k without fluid changes.
Agree 100%. The fluid you drained out and what was remaining on the drain magnets proves you were spot on to change the fluid.
CarbonSteel
Colorado Springs
If sticking to the Ford recommendations, it is:
Front Axle = Motorcraft 80W-90
Transmission = Motorcraft Mercon ULV
Transfer Case = Motorcraft Mercon LV
Rear Axle = Motorcraft 75W-85
I deviated in the front axle (used 75W-110 because I had it) and rear axle (used 75W-140 because I had it).
With that said, Dana specifies 75W-140 in both the M210 (front axle) and M220 (rear axle).
Ducati1098
60k is just typically when I start to see ULV getting darker on most 10R’s. That doesn’t necessarily mean anything is wrong with the fluid or transmission. But personally that’s probably the time that I’ll start to consider changing it out. Could it last until 100-150k? Maybe. But I have enough transmissions to rebuild without mine being one of them 😂
Rednek
Jimmy
Northern Alberta
2021 Bronco BD/2023 Maverick XLT/02 F150/68 Torino
I hear you man, I will be doing the harsh shift TSB on mine(and installing a PPE aluminum pan) as soon as I clear out some of the 10R's I have apart already.(That'll teach ferd to be in cahoots with GM!)
CarbonSteel
Colorado Springs
Agree, but I would add the vast majority of all metal generated (in axles, transfer cases, or transmissions) is done at less than 20K miles and from that point onwards less metal is generated on a per mile basis.
Ergo, it is more important to change the fluid early and often even with "conventional" fluids versus going longer with synthetics. I have a Mishimoto pan for my 10R60 and plan to install it at 10K miles. I will likely do a few fluid dumps after that to replace as much of the old fluid as possible.
mb86gt
Matt
KC
06 Silverado
Curious if Dana recommends 75w-140 in the M190 front diff as well?
CarbonSteel
Colorado Springs
Not sure about that one, but it would not hurt anything in the slightest. I have never seen an axle (or any moving equipment) fail in all my years from using a heavier viscosity oil, but I have going the other way.
mb86gt
Matt
KC
06 Silverado
Carbon, thanks for the reply. I appreciate your knowledge. I think I will split the difference and go 75w-110 in the front.
da_jokker
Jeep Wrangler JKUR
I changed mine out for really only 2 reasons...
1) I wanted to go the best Full Synth...Amsoil (at least in the Diffs)
2) I didn't trust that Ford filled them correctly.
Now that I've done it, other than maybe the t-case (because it was super easy and running LV non-synth)...I have no intention on touching my diffs again for a very long time.
orion
Jeremy
17' F-250, 17' Explorer
I don't know about changing it everytime, but I would definitely check it after a water crossing day. I would be changing my diff oil after almost every outing. Lots of water crossings here. Your diff breathers are there for a reason. If you are getting water contaminated oil frequently, your breather may be clogged.
