SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
Thank you for the thorough explanation along with the photos, based on my current setup the relocation bracket should suffice.
Happy to help bro :)
Fordified1
Bob
Mid South Texas
I was surprised to see the Watts Link on the Ranger Raptor and the drop out center section (diff). Wish the Broncos had that setup.
GTTom
Tom
New Hampshire
2023 Bronco Wildtrak
Because of all ya'll, I spent more money on my Bronco and got the Fabtech version. It's real beefy and got it for $106 shipped!
The Fabtech bracket looks beefer than the Rock Jock bracket. Made of 1/2" steel vs 3/16" of RJ's and It adds a gusset brace, wraps around the axle mount with an extra mounting bolt. Don't know if its necessary but looks heavy duty. Keep us posted on how the install goes.
B22-2023
Houston
So, I'll start this off by saying this - if you have lifted your Bronco and don't already have a Relocation Bracket for your trac (or track) bar, get one. It just works. And yes, EVEN IF you already have an Adjustable Track bar....
After looking at my lifted & settled setup closer, I’m dead level at 0 degrees measured. Looks like I don’t need the relo after all first glance, but I articulate a lot and speed on bumps so I’ll see what they say at Rock Jock. I don’t mind moving back in the relo but probably moving UP isn’t the right plan.
Ford Bronco Rear TracBar Relocation Bracket - Get One! IMG_0301
Ford Bronco Rear TracBar Relocation Bracket - Get One! IMG_0302
SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
Hmmmm....Could you show a shot of the rightmost connection point on the track bar? I'm wondering where it connects to have that kind of an almost horizontal angle.
BUCKIN6VA
Northern VA
www.youtube.com
'12 911 GTS, '25 Model X
Is that the ICON track bar? Looks like it’s on backwards. Their install instructions have the adjustable side on passenger.
Fordified1
Bob
Mid South Texas
I believe Some are adjustable on both ends… right-hand threads on one end and left-hand on the other so you don’t have to un-bolt it to adjust it.
B22-2023
Houston
Poppavein
Redmond, WA
Harleys, Ducatis, 2024 Bronco
B22-2023
Houston
B Miller
Sherwood, OR
Question: Can I add just the bracket to a factory SAS Badland Bronco and gain improvements? OR do I need to add an adjustable bar as well?
BoverW
J
Socal
The best way to determine this is to measure the height difference between the two ends of your rear trackbar. If ~ 2 inches, a bracket could help (Boss4x4 recommends this for SAS model, their bracket raises it by 2 3/8'').
All Bronco models use the same non-adjustable trackbar. Assuming non-sas is parallel to the ground, then sas definitely won't be. However, you have an overland build that may lower the rear enough so you don't need one.
KABQ
Aaron
Albuquerque, NM
Just bought the Rock Jock one. I definitely need it.
Ford Bronco Rear TracBar Relocation Bracket - Get One! PXL_20241122_231450979
crenca
Southern New Mexico
I was wondering if Boss or any of these other manufacturers quote measurements (of adjustment). Eyeballing my sasquatched Big Ben, which has a little bit of weight added to it in that I have added steel skids and what not, I estimate it would take an inch or an inch and a half of rise to get the track bar level. Thus, I think most of these relocation brackets would be too much. I need to crawl under there and do some measurements to find out fer sur...
Edit: does anyone sell an "adjustable" track bar relocation bracket?
SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
Note - that the purpose of the bracket is NOT to completely get the bar horizontal, but "as-close-to." I have a Big Bend too and have added a full compliment of RCI skids.
