Change Driveline Fluids Early!
Callelk
Larry
Idaho
Escalade ESV, Cherokee 2-Door
@CarbonSteel
Many thanks. Used my pass points for the cover and purchased the hardware from MMC. Amazon has the "-A" oil filter which I will use at my 1K oil change and then at 3K I will do the diff's, T-Case and engine oil. After that it will be 3K or twice a year for the engine oil change (don't drive much so whatever comes first) and then every other spring for the rest. Transmission will probably be at 10K with a new filter and deeper pan.
The Bronc
MJ
Nashville, Tennessee
04 Xterra; 04 Element; 06 Sentra; 10 Rav4
I changed the fluids in all 3 yesterday. CarbonSteel was an excellent resource and help. I really appreciate you CarbonSteel and the contributions you have made to the thread and forum at large. Everything went textbook because of the detailed write ups and videos. I was able to easily remove and reuse the plastic brake clips because of the detailed explanations. My fluid looked okay. The rear differential fluid was the darkest. There was no magnet on the drain plug to the transfer case. I am not sure if that is normal or a mistake during my build. This is something anyone can do if they have the right tools and a few hours. Read and watch all the videos you can first. It will save you time and money in the long run.
Please beware...my transfer case drain plug did not have a magnet. The drain plug was identical to the fill plug. CarbonSteel has confirmed the drain plug should have a magnet. This is another reason to drain your fluids early. I will now order a drain plug with a magnet and change the fluid again.
Ducati1098
They must’ve changed the plug at some point. The majority of the ones I’ve seen, do not come with a magnetic plug. Mine didn’t have one either. Like yours, the fill and drain were identical.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Perhaps it’s just a difference between 4A and Part-Time?
Mine had a magnet. June 2021 build, part-time 4x4.
Ford Bronco Change Driveline Fluids Early! IMG_5862
Ducati1098
I considered that also. But @CarbonSteel has a Wildtrak just like me, so we both have the advanced transfer case. Yet his had a magnet and mine did not 🤷‍♂️
redone17
Cold Spring, NY
Oh, weird.
The Bronc
MJ
I am not sure if that is by design? Maybe it has to do with supply constraints? I will call my dealership tomorrow to inquire. I have not been able to find the OEM drain plug anywhere online.
Ducati1098
I looked through the ford parts catalog and I cannot find the advanced transfer case drain or fill plug anywhere in the diagrams. So it’s hard to say if something was changed.
The only one I can find is for the part time transfer case which is completely different.
The Bronc
MJ
Are you just going to leave it as is or try to get a plug with a magnet? I like the idea of a magnet taking out what metal it can collect.
Callelk
Larry
Idaho
I take it that they are 1/2 NPT............
Ducati1098
I’m probably just going to leave it personally. I’m not overly concerned about it.
Yep I believe so
CarbonSteel
CarbonSteel
Colorado Springs
2023 Carbonized Gray
They should be 1/2" NPT.
Here are some from McMaster:
Low-Pressure 316 Stainless Steel Plug with Hex Drive, Hollow with Magnet, 1/2 Pipe Size
https://www.mcmaster.com/1457N14
swamp2
That's flangeless (and washer-less). Is that correct for the Advanced Transfer Case? Does the front diff use the same plug? TIA.
Ducati1098
Yeah that looks like it should work.
I’d have to double check, but I think the only difference is the factory TC plug is aluminum, while the diff plug is steel. Nevermind, they're both steel.
CarbonSteel
CarbonSteel
Colorado Springs
I am fairly certain the front axle, transfer case, and rear axle all use the same plugs.
They are flangeless and washerless because they have tapered threads that use a friction fit to tighten.
