Change Driveline Fluids Early!
swamp2
Here is a thorough and quantitative test of over a dozen gear oils.
Although conducted and authored by Amsoil, I still believe they have been fair/unbiased. I also don't agree with their simple equal weighting across criteria. Regardless, Amsoil came out on top. It's a great read and unlike anything I've ever seen on automotive lubricants. I'd love to see something similar for motor oils.
Link to my original B6G post and the report .
GroovyGeek
Boyan
'23 Bronco BD
You can buy the studs and bolts from Belmetric though?
I can, but both Belmetric and McMaster want $10+ shipping on $15 orders. I know, silly, but I was trying to consolidate the orders and pay only one shipping fee. Yeah, silly, I know. $50k+ rig, trying to save $10 on shipping. So sue me... :D
By the way, what is the length of the original bolts and the length of the studs from the base of the nut flange to the top? Trying to match that as much as possible to make sure that removal of the brake like clips does not become too problematic.
CarbonSteel
CarbonSteel
Colorado Springs
2023 Carbonized Gray
Gotcha. Here from McMaster:
Studs - https://www.mcmaster.com/5580N148/
Bolts - https://www.mcmaster.com/93474A217/
Nuts - https://www.mcmaster.com/97765A120/
Magnetic Plugs - https://www.mcmaster.com/1457N14/
Original bolts and studs from the OEM cover or from the Ford Performance Cover? Note the threaded bosses in the rear axle housing are all 23MM deep. Whatever you decide to do, be sure that you have at least 16MM of thread engagement.
OEM Bolt:
Ford Bronco Change Driveline Fluids Early! OEM Bolt
OEM Stud Clip Side:
Ford Bronco Change Driveline Fluids Early! OEM Stud Clip Sid
OEM Stud Cover Side:
Ford Bronco Change Driveline Fluids Early! OEM Stud Cover Side
FP Bolt:
Ford Bronco Change Driveline Fluids Early! FP Bolt
FP Stud Clip Side:
Ford Bronco Change Driveline Fluids Early! FP Stud Clip Side
FP Stud Cover Side:
Ford Bronco Change Driveline Fluids Early! FP Stud Cover Sid
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
hotrodtim
TIM
23 F-150-RCSB 22 WILDTRAK 19 EXPED. 68 BRONCO
As "CarbonSteel" posted ,Belmetric hardware. I did find that the plastic clips removed very easy and not damaged . That said I did reuse them . Works well. Long term I did order the 75mm studs and locking nuts in case .Now complete diff and transfer case fluids changed at 2500 miles. Mercon LV and Amsoil products were used. I want to thank "CarbonSteel" for his in depth article on this topic. Well done!
Ford Bronco Change Driveline Fluids Early! IMG_9762
CarbonSteel
CarbonSteel
Colorado Springs
That has me wondering if this was enough…
That appears to be about 16MM (length with no washers would be about 20MM), but it is not accounting for the thickness of the cover or the gasket. You may have 5-7MM of engagement--maybe...
GroovyGeek
Boyan
'23 Bronco BD
As "CarbonStee" posted ,Belmetric hardware. I did find that the plastic clips removed very easy and not damaged . That said I did reuse them . Works well. Long term I did order the 75mm studs and locking nuts in case .Now complete diff and transfer case fluids changed at 2500 miles. Mercon LV and Amsoil products were used. I want to thank "CarbonSteel" for his in depth article on this topic. Well done!
What hardware did you use for the plastic clips? Does not seem to be the 75mm studs. By my math 60mm studs with 4mm and 2mm washers from belmetic should work - 13mm thread engagement (short side), 10mm to top of cover (23mm), 6mm washers to take you past the unthreaded section (29mm), 14mm for the nut (43mm), and 17mm protrusion for the clips (60mm). This will be slightly less than the OEM 20mm protrusion. Alternatively with a 65mm stud you will be at 22mm protrusion. Don't have a sense of how much play the brake like has to put clips back on, so trying to minimize the overall stud length.
PWillette
Parrie
Maine
IMO, w/ the thread locker you'll be fine if you can get 6-8 full turns. On mine I just ground off the raised shoulder a bit until it would fit in the recess.
EDIT: I have the ARB, not FP
CarbonSteel
CarbonSteel
Colorado Springs
At 22 lb-ft or less, you **may** be ok, but anything more than that, you would be asking to strip the threaded boss.
I am doubtful that with the Ford Performance cover and the OEM gasket that you would have 6-8 turns of engagement on the stud shown with the washers.
That is about 16MM of thread, and you are going to lose another 8-9MM for the cover and gasket. The gasket does not compress much because it has steel inside it to prevent over torquing.
Proceed with caution...
CarbonSteel
CarbonSteel
Colorado Springs
If you want 65MM studs, I have some that I will mail out to you. I bought two each of:
65MM
70MM
75MM
80MM
90MM
to determine which fit my setup the best (which was 75MM).
The brake line has some play in it--it is not super rigid. As long as you have 20ish MM sticking out from the cover, you should be fine to reattach the plastic clips.
raptorusmaximus
Horicon Wisconsin
2012 F-150 Raptor
I changed mine @ 25k miles, the fluids looked fine. I filled royal purple 75-140 for both front/rear and valvoline for the trans case.
I wish the ford perf cover would fit on the raptor.
vrtical
Doug AI
GSMNP, TN
Fords
for sure there are D50 covers but they are way too much $$$
hotrodtim
TIM
With the new Ford Performance diff cover comes a new hardware kit and gasket which 'I didn't use . the hardware kit included the new brake line studs with attached nuts that I used from the kit. Didn't measure them because the test fit was perfect. The 10 Belmetric new bolts and 2 new studs from the Ford kit all torqued to 24ft. lbs without any trouble.
GroovyGeek
Boyan
'23 Bronco BD
65MM
70MM
75MM
80MM
90MM
Very kind of you to offer but if I am ordering bolts and washers etc then the studs are just a few extra bucks, not worth wasting your time.
swamp2
Wow, what a generous B6G fellow you are!
