Gear selector not illuminated
AlienHunter
Alien
Mid Atlantic region
My 2025 OBX Sasquatch is mostly a “hanger queen” in my garage. Last evening I had it out and noticed the gear selector isn’t lit. Is this one of Ford’s shortcomings in the Bronco or is this something I need to make an appointment at the dealership?
broadicustomworks
Hanging Rock, North Carolina
The one on the console beside the shifter (assuming it is automatic)?
If so, those are a decal/ look almost screen printed.
No lights to light up.
The indicator is on the gauge display.
TLO
Canada
youtube.com
2 door
Another example of Ford cheaping out and profiting...
My 2019 Escape didn't illuminate either... But 2018's did 🫩
Also, they turfed the led tails for shitty, single bulb halogens.
My 2015 Fiesta has more of the "little things" than my $75k Bronco
AlienHunter
AlienHunter
Alien
Mid Atlantic region
I wonder how in the F#€k did NTSHA give Ford a pass on that? After years of lit gear selector indications, that one threw me off questioning whether someone forgot to plug in the harness. Maybe if enough Bronco6g owners complained to NTSHA they will make Ford make some kind of fix. I don’t always look at the instrument cluster to see where my shifter is. Now that I know, I’m going to look at this being another way Ford is cutting corners. Before they would be displayed in both areas. I should be greatful at least they kept the shifter and not put in a rotary dial shifter as is in my Maverick which is one thing I hate. Leave rotary knobs to HVAC and the radio.
Ducati1098
Because per regulations, it just needs to be permanently displayed in view of the driver, which it is at all times. The NTSHA isn't going to make them change anything.
CalvinT
Calvin
Phoenix, AZ
I've never seen a manual transmission with a lighted gear selector.
Illuminated automatic gear selectors went away once manufacturers were able to display the information in the instrument cluster.
It's safer to look at the instrument panel for that information. Your eyes don't leave the road for as long. So I don't think NTSHA will ever require illuminated gear selectors.
Chrome_Pony
Chrome
The Great Land
Have you taken a center console apart? Is there even space under it to throw an LED?
I'll do it myself if it's fairly simple.
Ducati1098
I have not, so I'm not sure. However even with a light it may not shine through since it wasn't designed to. But I could be wrong
DarthLincoln
Chuck
Northern California - Contra Costa County
1999 BMW M coupe, 2023 Ford Bronco Badlands 2dr
Same. BMW has/had illuminated manual shifters to show the shift pattern, but it didn’t indicate which gear was engaged. I’ve never seen one that did.
Ford Bronco Gear selector not illuminated 1768938177244-b0
heavyD
Calgary, Alberta
2025 Badlands 2-Door
The illuminated shift knob used to be standard on BMW M cars but around the time the 2016 M2 came out it became an accessory.
Not the end of the world that the Bronco doesn’t have it but considering how much Ford is charging for these vehicles it’s kind of a petty omission. The printed markings next to my shifter were scratched on delivery and it looks dime store cheap.
Rydfree
Benny
Alabama
Why would you look down when they put a lighted indicator on the dash right in front of you ?
TLO
Canada
youtube.com
2 door
With my Escape there was... But the Bronco has never had an illuminated selector indicator so I highly doubt it.
