Cruise control not engaging in 6th gear.
GI_Jo_Nathan
Jonathan
Updated ProCal with the new gear ratio.
problem fixed. Loving the regear. Highly recommend.
That's great! Interesting issue it created.
  • Like
Reactions: gmo
totaljustice
Kevin
Middle Sackvegas, NS
Most do, the Bronco does not. It will let you shift and not disengage. It's pretty nice.
Something like this should have a reference to it in the owners manual. Like Vandy, with every manual transmission with Cruise Control I've ever driven. It would disengage whenever the brake or the clutch was pressed. I was using the Cruise the day after I bought my Bronco took an exit ramp and initially didn't require the brakes and expected the Cruise to disengage like I was used to so you can imagine my surprise when I downshifted and Bronco takes off. It freaked me out a little bit as I was totally unprepared for that. Later I searched through the owners manual and there is no reference in it describing this. I'm an experienced driver but I can imagine someone not ready to react to that might cause an accident because of that. I'm wondering if, it operates by design to help with the Goat modes, like the Hill Descent Control or the Trail Control where maintaing forward momentum would be the main concern. To me there should be a reference to that in the manual. After getting used to it, you're right it is a nice feature.
huey
kevin
Ontario & Kentucky
VW GTI VW EOS GMC Envoy Badlands Bronco
hey GMO - would love to hear some more details on the rpm's you see in each gear
As well as boost levels or maybe even fuel improvements? I'm not expecting big fuel gains but if you gain a lil why not celebrate the small W's
As we all know 6th is pretty much useless on this setup and that's really disappointing
