Ford Performance bead lock ring - Real World review?
userdude
Denton, TX
2023 2dr Badsquatch
I'm not arguing with you, and I understand the nuanced difference between "illegal" and "not DOT approved".
However, disclaimers like this ones below from the wheel manufacturers certainly give me pause regarding accuracy of your "not unsafe" assessment.
KMC: " Bead locks are not DOT approved and are not recommended for on road use."
Raceline: " (BEADLOCK WHEELS ARE FOR OFF-ROAD USE ONLY & ARE NOT DOT APPROVED FOR HIGHWAY USE) "
Ford Performance / Ford Motor Company: "Bead lock configuration is for off-road use only"
Method: "BEADLOCK WHEELS ARE DESIGNED, ENGINEERED AND INTENDED FOR OFF-HIGHWAY USE ONLY AND ARE NOT DOT APPROVED"
Maybe they are all just trying to protect themselves from liability, but IDK. Seems not worth the risk for my daily driver.
I was out with a guy at Merus who had some Icon wheels that he called "prelock" (I think), which I think is this InnerLock. It looks the same. He said they were also DOT approved.
https://iconvehicledynamics.com/innerlock
Bellime
Keith
2022 Ford Bronco
Sasquatch, Badlands optional, and Raptor are all Beadlock capable. Raptor uses a different style of ring tho IIRC. The beadlock ring for Sasquatch fits a Raptor wheel but looks wierd
https://performanceparts.ford.com/part/M-1007-DC17A
https://performanceparts.ford.com/part/M-1007-DC17B
Thanks. I like the look of the badlands better. Is there any functional differences? At ~$900 a piece or $4,500.00 for a set it will be a while, but my plans are letting my stock tires wear out then do the upgrade.
Bellime
Keith
2022 Ford Bronco
Strizzo
Houston, Tx
Lexus GX460, 1966 Mustang Convertible, Jeep Wrangler TJ
I went with the Method Bead Grip wheels.
I'm not sure how low you can run them as I only go down to 20psi but I suspect they will stay on way lower than that. Not sure how you rate wheels as to when the bead won't stay on. Experience I guess.
Then I just air up for the street.
https://www.methodracewheels.com/pages/bead-grip?view=beadgrip
If you're running low speed, rock crawling, you can pretty easily go down to 10-12 psi on standard wheels, and high single digits on the beach without much issue.
Nate from Dirt Lifestyle on Youtube ran down to almost zero on bead grip wheels and they held the bead. They seem to be a great alternative to full beadlock wheels for the majority of off roaders.
swooshdave
Portland, Oregon
Mustang
So what is the advantage of bead lock wheels. Is it just the assurance that the bead cannot debead no matter what?
If you can go down to 10 psi on standard wheels why would you want to go lower? You run a higher risk of damaging the rim at some point if you don't have any air.
Rkgzx9leftcoast
Robert
Scottsdale AZ
Jeep JL
They are sold as a set of 4 for the rings
Rkgzx9leftcoast
Robert
Scottsdale AZ
Jeep JL
Some run them even lower than 10PSI on snow and even off road. The main advantage of a bead lock is on obstacles if you get a tire in a bind a normal bead has more of a chance of popping the bead off at the lower pressures.
BAUS67
redneck
Central PA
A beadlocked tire will not come off the wheel. You can rip the tire to shreds and the bead will still be locked into the wheel. You can also get into a situation where the wheel will spin and not the tire a beadlock will prevent this from happening. That is mainly the issue in drag racing but I have seen it happen in the mud as well.
Ford Bronco Ford Performance bead lock ring - Real World review? 1690568949089
Strizzo
Houston, Tx
Don't think about the super heavy modern rigs these days, think about an xj cherokee or suzuki samurai running a load range c or d tire. some rigs need to run way low pressures to get the sidewall flex.
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
Badlands wheel is slightly narrower. I have both, and both have beadlocks and 1.5" spacers...note the tire on the BL is 37x12.0, the squatch has 37x12.5
Ford Bronco Ford Performance bead lock ring - Real World review? 20230728_143407
Ford Bronco Ford Performance bead lock ring - Real World review? 20230728_143335
Bmadda
Wisconsin USA
Also they have become standard equipment in dirt track racing. Late models use them on all 4 (cause they are special), Mods are allowed on both right sides now, and street stock uses them on the RR. Like most newer tech in racing they faced an uphill battle gaining approval 30 years ago, but now are in some cases mandated! They improve the show overall by cutting down on the "garbage yellows", and have proven completely safe if used properly
BAUS67
redneck
Central PA
Yes, I forgot about the dirt track guys. Don't forget the sprint car guys as well. 😁
Bellime
Keith
2022 Ford Bronco
Bellime
Keith
2022 Ford Bronco
