Running the Bead lock ring as a trim ring?
TwinTurboStang
TwinTurboStang
CT
Brodiak
I just like the look and having the even amount of bolts.
Ford Bronco Running the Bead lock ring as a trim ring? 1912144E-48C4-49FE-A51B-616BD7745B04
Ford Bronco Running the Bead lock ring as a trim ring? 1B1FA57A-D7D3-45CD-A1FA-3926899C4BA6
Ford Bronco Running the Bead lock ring as a trim ring? CD3BA2CA-8BEA-4D10-9095-11F178226BB1
Broncotrax
NORCO
69 Bronco, '17 Superduity, '22 Badsquatch, CR 250R
The beadlock ring would have kept the tire on the wheel
Yeah I just watched it again. He didn't slip the bead, he pinched the sidewall. C'mon readers,...understand what these are for!!! Beadlocks do not keep you from pinching holes in your tires.
Broncotrax
NORCO
trail where you may need beadlocks. Let me know if the link didn't work.
Mahin2021
Coeur d Alene, Idaho
F250 TD
If you assemble them as the designated beadlock they are non DOT approved in many states so this puts you in a "hard core" rock crawler group where you have two sets of tires/wheels. Also most people on this site will never be in a situation to actually NEED beadlocks because that severe wheeling takes a toll on a vehicle. Being brand new,.. I don't see this happening. Lastly if someone really wants/needs beadlocks. Go with the Icon wheels, they are lighter and DOT approved. When you see a hard core wheeler with true beadlocks it will likely be older and have rock rash, dents and such.
That’s what mine will look like after I do the Rubicon again this time with the Bronco. They are made to have fun off-roading not for show room looks.
TwinTurboStang
TwinTurboStang
CT
Brodiak
Gap is crazy big. I think I’m going to just set the stock rings up on cnc and drill the extra holes.
Here what it looks like
Ford Bronco Running the Bead lock ring as a trim ring? 3B6A50EC-3EBC-4635-98D6-829F03BE4EE6
Ford Bronco Running the Bead lock ring as a trim ring? 6AB99C3D-8C33-4CDD-95EC-D4F9ABB7C8FF
Ford Bronco Running the Bead lock ring as a trim ring? 511FB462-5795-4634-B9B7-3FCA3B08E0DA
Ford Bronco Running the Bead lock ring as a trim ring? 3EE8EFB0-0F32-41A4-B9A5-0331CF4CB8F4
Kmcran
Kyle
Biloxi, MS
2018 mustang GT
Bummer. I've wondered if the stock ones could be drilled out. OMF performance makes real beadlock and beauty rings for raptor wheels. I haven't reached out to them yet to see if theirs would fit.
Broncotrax
NORCO
Your a good man for sharing this info. Sorry it didn't turn out how you wanted.
Adventure on!
the poacher
john
Whistler
2010 ford ranger
I'm not denying that at all but I have been wheeling for 30 years aired way down all of the time and never lost a bead so to say that someone actually NEEDS them is quite different. Look at Litebrite videos on 21 road in Colorado. This is what I mean. You are correct that there may be several people rollong on beadlocks but I'm saying 99% of the stuff they will be doing can be done sans beadlocks
Hey Broncotrax,
I agree that with you that with today's wheel technology, the need for true beadlocks is diminishing. For most Bronco owners they will not be needed. But for the old school and dedicated, there will still be those that use beadlocks. I will end up having a separate set of beadlock wheels with 37" tires, for use on specific adventures. Day to day, I will use a set of non-bead locks with 35's.
babraunagel
Golden, Colorado
Toyota FJ Cruiser
I got 1 of the 17-18 raptor bead lock rings. Since they come in 4 packs figured I would need a 5th if I did do it. Ill bolt it on the spare and see what I think.
Please post a photo!
the poacher
john
Whistler
2010 ford ranger
And those fit the bronco rims with no issues?
TwinTurboStang
TwinTurboStang
CT
Brodiak
Fit perfect bolting on. I didn't flip the bead of the tire to do the true beadlock but looks right
BoogieBD
Boogie
High Dez California
I disagree with your thoughts Broncotrax. I believe that the percentage of beadlock rims used on Bronco's will closely mirror the percentage of beadlock rims used on Jeeps. There are many of us that intend on using the full capabilities of the Bronco, as it was designed. There will be a good percentage that are not just mall crawlers and will proudly show the dings and scratches that come with using the Bronco to its fullest...
šŸ’Æ percent agree with you. God damn mall crawlers 😁
BoogieBD
Boogie
High Dez California
I’ll be flipping the bead here next month when I get it. I’ll post a picture here. I do a lot of driving but not daily. Mostly on weekends for the adventure and I do feel that I will be needed them as I tend to get myself in rough spots from time to time. That’s when I worry about airing down below 15psi I have seen people on the trail pop a bead and it hasn’t been fun. Did you end up cnc the stock rings?
