black beauty ring bead lock capable wheels
Signals34
Sal
Bethlehem, PA
2019 jeep Rubicon
are these rims beadlock rims or not?..... 17” Black High Gloss-Painted Aluminum with Black Beauty Ring Beadlock Capable Wheels ....i like the look of these rims, but i dont want beadlock rims....
contented
Karl
Central Fl
BMW M2 Competition
Sal, welcome to the forum. No they are not beadlock wheels. I call them faux beadlocks. If one wants true beadlock rings, Ford is happy to sell them to you for $800 - $900.
edit - the reason they’re called beadlock capable is that if you remove the trim ring, the wheel itself has a series of drilled holes inbetween the holes holding the trim ring on.
Signals34
Sal
Bethlehem, PA
2019 jeep Rubicon
thanks....so i can remove and install a tire on these rims without removing that trim ring, treat it like any other rim....
contented
Karl
Central Fl
BMW M2 Competition
That’s correct. Although folks here have reported poorly trained tire techs thinking they had to take the ring off.
I scratch the rings up every trip to Moab. After returning home, I remove, sand, and repaint them.
Ford Bronco black beauty ring bead lock capable wheels IMG_2326
Ford Bronco black beauty ring bead lock capable wheels IMG_2325
Ford Bronco black beauty ring bead lock capable wheels IMG_2323
NaMinesClarence
Northern Metro MN
2022 Badlands Sasquatch
I powder-coated mine carbonized grey, so I took mine off before tire installation for peace of mind. After my tire install I set my air pressure at home, my spare was about 70psi ...
