Ford Performance bead lock ring - Real World review?
Merc4x4
steve
NJ
Not my intent, just saying
you're saying something you cannot back up.
that would require looking into the laws of (at least) every state. looking for prior cases (in each state) for precedence. interpreting the law and arguments and guessing how a judge would rule (in each jurisdiction).
the argument has been rehashed on the internet a lot. I won't continue here past this post.
nolimits
23 Badlands
Keep in mind that the BL wheels are 8ā€ wide (Sas 8.5ā€) and offset is also different. BL is 55mm offset, Sas is 30mm.
Good point. FYI, the optional BL wheels were only offered a short time, I think through 22. I know my 23 didn’t have that choice.
I have a non-SAS BL and plan to pick up some SAS takeoffs, sell my non-SAS wheels, buy the functional locks and sell the beauty rings. If things go my way I will have $500 or less in them once I’m done. My company pays for the rubber so $0 on that side. šŸ˜Ž
$1100+ for a set of 5 from FP is ridiculous.
Check Lethal or CJ’s. Both around the $800 mark and CJ’s has an 8% off email offer making them slightly lower after discount.
https://www.cjponyparts.com/ford-pe...ng-kit-set-of-5-bronco-2021-2023/p/M1021KBL5/
https://www.lethalperformance.com/f...2021-2024-bronco-2022-2024-bronco-raptor.html
Ford Bronco Ford Performance bead lock ring - Real World review? IMG_0453
nolimits
23 Badlands
I decided to go with the ICON Recon Pro 17ā€, only beadlocks approved for full time use, look great with K03’s on them.
I don’t care for the aesthetics of the Recon wheel myself. I do like their Rebound Pro though and have considered them. Many of the guys running them have good things to say about their innerlock system
The Recons do give you the removable and replaceable rings and so far is the only ICON wheel that does. Granted they’re plastic/HDPE.
Also both wheels can be had with 25mm offset and 95.1 bores. Which strikes me odd as our Broncos have 93.1 bore hubs.
While there are some things I still like about the Rebound Pros, I think the SAS is the direction I’m leaning. Obviously YMMV.
BigMeatsBronco
Allan
2021 FE 2 door
Bellime
Keith
2022 Ford Bronco
telenerd
telenerd
Laramie
Subaru
Still debating on ordering these! I was at 13psi without the lock rings and felt great. Cant imagine what 8 or 7 psi would be like with the rings. No good deals. Trying to catch a sale or find gently used ones.
Zus
Matt
Atlanta
82 & 22 Bronco, 17 F150, 12 Expedition
I just bought mine. I wanted these as a back up set of wheels. My all terrains are too nice and balanced to jack them all up. I get in a ton of highway driving so I want comfort outside of the trails. I am stoked. Can't wait to try them out aired down confidently for
Ford Bronco Ford Performance bead lock ring - Real World review? 1000009621
once.
Zus
Matt
Atlanta
The difference from BFG AT 37s to Mickey Thompson MT 37s is crazy. BFG might have 1000 miles on them.
Ford Bronco Ford Performance bead lock ring - Real World review? 1000009616
MhdS
Canada
bronco wildtrak 2 door
Any good forged or billet aftermarket lock rings that are compatible with the Sas beadlock-ready wheel?
100% agreed, have you found anyone else that does them? i don’t care for the ā€œFPā€ branding. just the function.
telenerd
telenerd
Laramie
Subaru
Looking to try and install these at my house so I don’t have to deal with a 19 year old kid at a tire shop. I already have new tires mounted, but looks like I need to pop outer bead and then easy going from there.
Any suggestions?
