userdude
Denton, TX
2023 2dr Badsquatch
Is there a thread that explains all of this step by step for those that are following. I have a WT 2.7 with 12k. I'm usually lucky to keep a car to 20k, but this damn Bronco is a keeper and want to go the extra mile. I have never changed fluids in a transmission, or diff and would appreciate some details. I found the Valvoline and the pump, but not seeing the frame oil on amazon and only "Genuine Ford Fluid XT-10-QLVC MERCON-LV Automatic Transmission Fluid - 1 Quart"
Any directions/step by steps would be appreciated!
That oil coming out is low and dirty ((Needs addressed!!))
https://www.bronco6g.com/forum/threads/change-driveline-fluids-early.83929
CarbonSteel
Colorado Springs
2023 Carbonized Gray
Curious as to why you went with Mercon V versus the specified Mercon LV. Also curious as to why you would use an unlicensed version of Mercon (even though it is not the correct type)?
CarbonSteel
Colorado Springs
EDIT - Link to my videos: https://www.bronco6g.com/forum/threads/change-driveline-fluids-early.83929/post-2108566
I'll be changing mine tomorrow and will write up a step by step for it. I would be happy to walk you through it.
Mercon LV is the correct fluid for the transfer case--not sure why the OP went with Mercon V. You can pick up 5 QTs for $39 on Amazon. I bought two because I plan to change it a few times before calling it good:
Ford XT-10-QLVC 5 Quart Mercon-Lv Automatic Transmission Fluid 1 Pack https://a.co/d/1xvc5rc
MrGreen55
Kyle
Oregon
toyota scion xb
I was think about doing with my first oil change at 5k. is it better to wait in tell 15k not sure if ford put brake an oil in the diff.
bkfit
bkfit
BK
Spaceship
Mercon V is better if you live in cold climates. Had on hand. LV 5qt arrives tomorrow. Will switch out…
Ryan Feilner
Ryan
Omaha, NE
That would be great! Let me know once you post and will be sure to follow the steps! Appreciate it!
Ducati1098
The 10 speed takes Mercon ULV, which usually stays pretty clean unless you have an internal issue. I would say it starts to get a little dirty on most vehicles I see around 60k. So no really need to worry about that anytime soon.
CarbonSteel
Colorado Springs
How does that work? Mercon V is thicker at every temperature.
Ford Bronco Diff & TC fluids changed out. Screenshot_20231209_074642_Foxit PDF Editor
Ford Bronco Diff & TC fluids changed out. Screenshot_20231209_074633_Foxit PDF Editor
CarbonSteel
Colorado Springs
I'm changing mine at 10K to remove break-in metals and to install my new Mishimoto pan. I'll post photos when I get another 5K on it.
BluebroncoNC
Stroppe
2025 Stroppe Bronco & 1977 Bronco
Stroppe
So, you take the plugs out before you go 4 wheeling to let those areas "breath"?
I can honestly say, "wow" ... and it is prompting me to investigate mine.
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
Tip: When removing diff cover leave the top bolt loosely in and your cover will never fall in to the catch pan.
Beautiful helper you got there!
The Bronc
MJ
Nashville, Tennessee
04 Xterra; 04 Element; 06 Sentra; 10 Rav4
Well I should have done this 1.5yrs ago on Redrum. 2021 Basesquatch 2.7 Rapidred. 22,200 miles.
Thanks @CarbonSteel for the reminder 🤙🏽
Do you have the torque specs?
Did you put the 75w-140 gear oil in the front and the rear?
vrtical
Doug AI
GSMNP, TN
Fords
Joining the 10k club. Doing 75w140 Valvoline in the diffs and Motocraft for the transfer.
ramblinwreck
Georgia
`22 Wildtrak, '21 Wrangler Rubicon 4xe
I’m pretty sure the fluids turn dark brown like that within 1k miles or so. I don’t think that’s an indication the fluid is bad
