mpeugeot
Thanks for the detailed response. I appreciate that. How much lift did you get out of the box? HD or normal springs? UCA required for alignment?
I like the 6112 but I like the adjustability of the Eibach a bit more I think.
I will take a picture of it today in a bit.
I would estimate 3" of total lift, normal springs (doesn't sag too badly even with 500# in the back.), I put UCA's in... I have a set of 4WP UCA's I am looking to get rid of btw. I don't think that the UCA's were required, but I did them anyway along with the rear trackbar relocation bracket and adjustable trackbar. Although, the bracket would have been good enough (but perfect is the enemy of good enough). I got it all aligned after I installed everything. All in all it wasn't too difficult to install.
baseline mac
SC
base 2 door
  • Perch collars, stiffens the ride and okay if low mileage.
  • 5100s Bilsteins are the cheapest recommendable shock replacement, they have better dampening with increased road feedback. Best option for NON-SAS Broncos.
  • 6100s Bilsteins are an upgrade over 5100, they are better suited to bigger tires only work on SAS broncos. Best option for SAS Broncos.
  • Eibach Stage 2.0 Pro Truck with normal springs, "subjective" but most likely the best ride, they are designed for less road feedback. Best option for a 35" and smaller tire and if you are fairly stock. Have easy adjustment to get that perfect lift.
0-2" Lift on 35s from Malls to Mild Trails -Your not going to disrupt the driving characteristics or effect long term reliability
So if I have a base 2 door I can go 5100 and not need anything else to get my desired lift? No springs or extras etc?
Snacktime
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Yes, no extras needed with 5100s. The only "recommend" item would be zone upper control arms if you think it drives to darty and you want more caster.
baseline mac
SC
base 2 door
Thanks for the quick response. Lots of data to sift through.
baseline mac
SC
base 2 door
So now the question is (instead of starting yet another post) where do I buy said 5100's and who has the best deal?
PetePerkins
Pete
TN
2024 Black Diamond
Last month I purchased my 5100s from Northridge4x4 for $140 each. BTW, I love the ride on my '24 BD with the 5100s and stock springs. A bit stiffer or not as cushiony, with a nice stable feel.
Snacktime
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
mpeugeot
I owed you picture.
The center lower lip of the fender is apx 40.75" both front and rear.
Ford Bronco 2025 Suspension Recommendations (by Snacktime) IMG_20250708_133238565_HDR
That's how they look out of the box with the standard springs in the Eibach Pro-Truck 2.0 kit.
Snacktime
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
That sealed my fate on those wheels. Thats perfect.
The RTR wheels hold up extremely well and the correct bore center is just icing on the cake. Would be an excellent choice in 0mm offset!
mpeugeot
I went with the +30, they have been great so far, so either 0 offset or +30 work fine with 315/70r17's
Jack667
Jack
Milton, GA
Yamaha WR250R
Looking for opinions - it's so cool that everybody has one! :)
I've searched and seemingly read every post on no lift base-ish suspension with 35s. I haven't seen this Q or opinion: Base-ish suspension with 35s, less stress with lift or no lift?
If one isn't going offroad with much of any articulation or speed / compression, and leaving aesthetics out of it (how cool or not a lift looks), for someone running 35s, would it be better to do a spacer lift or leave it as 'no lift', from a wear / stress standpoint, for components like tie rods, ball joints, and CV axles?
Newbie here and trying to decide about upgrades. Already have a non-Sas black diamond coming in this week and a set of sasquatch takeoff Wheels & Tires in the garage [edited in to specify that I don't have takeoff coilovers]. Planning to remove crash bars and run the 35s for a bit like that, and maybe stay that way. Seems like 5100s are best bet for a lift. Thx for that info! Shop says not to bother swapping new stock shocks with 5100s - do that when there's 30k miles on them and save $1k - go with spacers for 2" lift. But also considering leaving as-is and curious if no lift would be less stress on components - especially if I like the ride and the look. TIA
Oldhippie
Barry
Santa Cruz, Calif.
BMW X1, ā€˜1928 model A, ā€œ23 Bronco
If ya already have Sasquatch coilovers…run them with 35ā€s….nothing else needed except removing crash bars…
Jack667
Jack
Milton, GA
Yamaha WR250R
My bad - meant to specify that I have Sasquatch take-off wheels/tires, not coilovers/suspension. All stock HOSS 1.0, Big Bend/Black Diamond
