- First Name
- Peter
- Joined
- Dec 3, 2021
- Threads
- 8
- Messages
- 422
- Reaction score
- 715
- Location
- Kingman AZ
- Vehicle(s)
- 2023 Bronco 2Dr - 2022 Bronco Raptor
- Your Bronco Model
- Base
Be careful with solenoids... winches will draw huge amp loads. Look at the manufacturer charts. 500amp is not enough. I'd make sure you have a quality (not china part) and check that it can withstand the under hood temperature range and waterproof.
Realistically a switch is probably the better option for high amp winch load.
However I've always wired directly to the battery. I've owned a dozen winches over 20yrs and never had an issue. Ensure good connections, protect wiring and carefully route - these are the cause of most issues I've seen.
