37’s with no rubbing off road?
jaeggernaut
BMW M Coupe // Volvo P1800S // Caterham CSR 200
I’ve been thinking of putting 37” tires on my badlands Sasquatch. Watched a bunch of videos but couldn’t find anything that seemed to have no rubbing on the trail.
Then saw the 74weld portals which looked more than perfect,…. Until I found out the price.
what’s the proper way of doing 37’s without breaking the bank?
popo_patty
Caleb
Sacramento
2021 Bronco/1996 Jeep XJ/1957 FC-150
You’re going to get a wide array of the same answers that havnt helped you on the other threads. There is no single cut solution as there are so many factors.
John over here will claim all he did was throw on different wheels and he has no rub and goes off-road all the time. But his definition of off-roading is driving on dirt roads that get a little bumpy.
Meanwhile Tom is smashing whoops at 79 mph and rubbing like crazy on the same setup.
A reliable, budget build on 37’s is very difficult. There are things that work but may not be reliable in the long term depending on what you do.
Start with one step at a time until you achieve no rub.
Get a suspension kit you like, 4WP, ADS, King, Icon whatever. Adjust it to what’s required to allow a 37 to fit. Turn your tires and you’ll see that you rub. Now you can either grab a 0 offset wheel or do the body mount chop. Some people do both, again it can depend. I have both and I still rub on high speed jumps on my DV8 inner liners. Also, don’t Jack up the coilover high to the sky as it won’t give any more clearance (because up travel remains the same) and jacking up the preload will hurt your ride and also create really bad angles. Lowest lift to fit the biggest tire ;)
A 12.5” wide tire will fit easier then a 13.5” tire.
And that’s about all you can do without starting to cut into your fender and relocate stuff.
If you buy shocks with reservoirs then make sure you mount the reservoirs where they won’t rub at stuff, this will depend on what suspension kit you choose.
I’m happy with my JKS tire clearance kit, King suspension lifted at 2” over Sasquatch height, and 0 offset wheels. I also have the DV8 liners which I’m not fond of and rub at full stuff. I’ve broken them up pretty bad at this point so that affects my rub as well. I know what it is though and I’m not hurting anything. If I didn’t have my liners then I wouldn’t rub.
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
Definitely agree with @popo_patty … there is no single way to achieve this, and everyone will have a slightly different approach depending on what they do with their vehicle. I just do one step at a time until you have achieved no rub.
Here is some of the stuff people have had to do in the past. Whether you will have to do them depends on exactly how you lift, and in the end you may have to do a little bit of everything.
  • 2”+ lift
  • Cut the crash bar/intercooler mount
  • Trim inner fender liners (or new liner)
  • New upper control arms
  • New track bar bracket
  • New wheels… probably with +15 offset or less
  • New trailing arms
tobyw
Toby
Washington
2022 4-Door
And don't forget that not all 37's are created equal. For example, I'd say that in general terms if a BFG tire is your flavor of choice, you'll have a easier time than someone wanting to run a Nitto...
fdchief
Ohio
2023 BadSquatch, 1995 F250, 2018 Rebel R2
just my personal experience, im running the eibach stage 2 kit from Panda and Cooper Rugged Trek 37s and i have no rubbing, but as others have stated im not out at moab every weekend so im sure for that kind of roading youll need more, but for the every day appalachian roads hills and mountains it works great for me.
Fordified1
Bob
Mid South Texas
PoPo above knows what’s up for sure.
I see you’re in Utah, so no doubt will need full articulation at some point. A combination of Max Clearance Kit, 2” lift and small body lift is my plan of action at some point.
Baja Bronco
2Sun AZ
22 Ford Bronco, 20 Ford Raptor
It’s going to cost a good deal of money, pretty much that simple. Great advice has been given. If you’re doing it for looks, stay with 35s, as 37s will wear components. If you’re going to go off road harder than graded roads, once again, money. You have to pay to play.
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
Truthfully there isn't, your suspension is not designed for 37" tires, so you would either change what is needed to keep proper geometry and drive angles, as well as re-gearing or go portals, all other options are janky compromises which will have their issues.
If you are adding 37's for superior trail capabilities these modifications would be a welcomed addition, if you are doing this strictly for looks, who care's! lol
Oldhippie
Barry
Santa Cruz, Calif.
I did zone 3” Sasquatch lift (with a arms and track bar relocation), JKS kit, and cut crash bar mounts, running 0 offset rims and MT Baja legend mt 37x13.50…they are close to rubbing around town, if it becomes a problem offroad, next step is body lift…good luck!
tobyw
Toby
Washington
2022 4-Door
Zone 3" Adventure series (ZONF97)? Just curious because I don't see where their kit addresses the track bar so what bracket did you use? I'm exploring my options on this topic as well...
Fordified1
Bob
Mid South Texas
I bought the Rock Jock bracket kit.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Secret setup for a sas bronco is 2" lift collars, 1/2" up to 1" body lift and crash bar modifications. Money should be spent on armor if your going to wheel. The stock suspension is not a limiting factor.
UniBroncorn
2022 Bronco Raptor
Trade in for a Braptor 😉
Oldhippie
Barry
Santa Cruz, Calif.
Rock jock…
Bradley Thornton
Bradley
Hattiesburg MS
