- Mar 26, 2021
- 17
- 96
- 62
- San Luis Obispo Area, CA
- 2023 Bronco Wildtrak, 2018 Mustang PP2
- Wildtrak
I am currently in the process of attempting to install this on my boss 3.0 wildtrak. The diff drop causes the diff to be approximately 1 mm (possibly less) from cross member.
also the stock bracket has captive nuts so you undo cross bolts and the captive nuts go with the old bracket. Am I supposed to use 2 of the 3 huge nylock nuts from the kit? I think 15/16. I haven't tried doing the rear lift, but only see 1 nut mentioned in the back lifting.
I don't know if my bronco is different or if my bracket is mangled or something but clearances make me nervous. Might check that on your broncos for those that installed the lift.
So far everything else has gone smoothly and the front ride height looks like it'll be nice once settled a bit.
