37” tire rubbing modifications
JF Bronc
Atlanta
Ford Bronco
Making room for the 37s on the back of the front wheel well where it rubbed the fender liner. JKS Max tire kit includes the brackets to eliminate the big plastic block behind the liner so the liner can be pulled in.
I trimmed the bottom edge of the liner, and used zip ties instead of the plastic push rivets to secure to bracket. Also cut off the metal body corner.
@PCDan - yes, 3 yrs after your post but I think I have a similar setup as yours (I have Fox 2.5 with 17x9 wheels with 0 offset) and therefore sounds like identical locations of rubbing with 37s.
I just put on Mickey Thompson MTs and see I need to cut the corner of the pinch weld and pull the front wheel fender liners back to rear of the wheel well.
Did you also cut off the fender liner near the pinch weld? It looks like that is what is catching when going in reverse with the wheel turned.
I see you used the max jks kit and that helped pull the fender liner back but did you think it was necessary to cut the crash bar bracket off? For me with my foxes, it doesn’t look like the crash bar bracket is an issue and it solely the rear of the fender well and pinch weld location. My first inclination was just cut off the whole bottom section of the rear of the fender liner.
Would welcome any feedback from your experience. Thanks.
PCDan
PCDan
Dan
Park City
1968 Ford Bronco
Hey there. Well it’s been a while but like I showed in the photos I did cut the bottom of the liner off, made a straight cut. And then cut the corner off of the pinch weld. I did not do anything with the crash bar mount. I still have slight rubbing only backing up, which I don’t care about.
I had to do a lot more cutting on the back side of the rear wheel wells to prevent bottoming out. Your Mickey Thompsons are not quite as big as the Nittos so you may not have to do everything I did.
have fun
Dan
BisSilent
TrailerPark
Mustang
I removed the plastic behind the wheel liner and cut the rear crash bar brackets...used zip ties to pull the inner fender well back. -25 mm offset Icon Rebound Pros
Ford Bronco 37” tire rubbing modifications 20250729_144118
Ford Bronco 37” tire rubbing modifications 20250729_144131
