mblur05
Los Angeles
2022 Bronco BlkDia. Sasquatch
Anyone have their Map/Dome Lights no longer come on when opening the door when parked not running? They should come on and the dome off button is not selected. I'm not sure which Forscan code changed this. I changed the Auto Headlight from "Auto" to "Last Known", thought maybe that was it so I changed it back but that wasn't it.
Anyone know the code section to check the Map/Dome Lights?
I also changed these code options:
Auto Headlight back to "Auto"
Door Open Chime -disabled
Seat Belts both Driver/Pass -disabled
Double Honk -disabled
Global Windows Open+Close -enabled
Fog Light Front Enabled all
and I thought I had disabled start-up Chime dododo-but nope.
85crawlrunner
Josh
Southern Utah
21’ Wildtrak
Yesterday I finally used Forscan.
Got rid of double honk, doo doo doo, seatbelt and door chimes, added rock crawl, change tire pressure setting…
I also tried to do global windows and had an error on pcm and dcm modules where it said “service procedure has been interrupted.”
Ford Bronco 2021+ Bronco ForScan Thread AED722AA-D15E-4172-89BE-2C79B2CB4153
I tried multiple times and on multiple he easy click enable way as well as using the hexadecimal route and had the same results.
The BdyCam module worked fine in processing but that doesn’t make it work obviously since I missed 2 modules.
I also reset tire size and had a code keep coming up.
Any time I go over 2890 on the circumference a “Service AdvanceTrac” warning pops up on the dash. I’m supposed to be at 2911 for my tires (KM3 37’s with actual of 36.5”) but the calc shows max size I can really put before the warning is for 36.25” tires.
Ford Bronco 2021+ Bronco ForScan Thread 938FABA6-6B3B-4E5C-9509-431A5B04B33F
Ford Bronco 2021+ Bronco ForScan Thread 2E97E866-617F-4D91-9CE9-CDE3047518F5
Ducati1098
The calculations don't add up correctly for some reason, but 2911 is way to high and not possible. There is a limit to the size you can change.
Set it at 2800 and check it against a GPS app. This is where I have mine set with 37's and its perfect. It should be very close for you and then you can adjust it little by little from there.
85crawlrunner
Josh
Southern Utah
21’ Wildtrak
Interesting. I wonder why the website would be off that much.
I’ll do the gps check and see where that gets me.
Ducati1098
It's not the website that is wrong. Even with all the correct math, it just doesn't match up in forscan for some reason. Its almost like the programming in the module is just wrong or something, I'm not sure. Mine were suppose to be over 2900 also, but after a lot of trial and error the number needed was much lower.
85crawlrunner
Josh
Southern Utah
21’ Wildtrak
Cool thanks I’ll give it a shot
71to21-2DR
Rick
Lincoln Ca.
Nissan Frontier 4WD
I played with the tire size settings until the GPS matched the speed. All the math, and measurements in world doesn’t seem to matter with the Factory settings on these Broncos.
At least I know It is accurate as possible now!
Golfsnob
St Augustine
2023 Base 2 Door, Manual, 2.3
I adjusted mine today. I installed a set of Badlands wheels/tires (33") on my base the day after I got but just now getting around to messing with Forscan. 2525 put me within .5 MPH which is close enough.
Golfsnob
St Augustine
Also realized I don't have the sport goat mode even though the factory parameters in Forscan are set for sport mode. Don't really care as I will get the Ford Performance tune when it's available for the 2023 but odd that it's not showing on the dial.
SevenT
1970 U15 Sport Edition; 2021 AMB 4 Door Badlands
Need some help here. I just tried to do some work on a 2023 Badlands and FORScan would not connect to the truck. It said enter the PCM # or tune type. This truck is still factory fresh. What is going on here? I am running a Win 11 PC with FORScan beta 2.4.6. Should I be running 2.3.52?
Mlarv
TN
The statement you are getting is because Forscan does not know all of the 2023 information. You can get an extended license from the Forscan group, then send them an E-mail with your VIN and they can fix that for you.
I just downloaded the newest Forscan software yesterday and will be trying it today on my 2023. I just traded out an OBX for a Badlands, so I have to fix some stuff the way I want.
SillyPosition
Silly
Israel
None
Do the exhaust sound differs between normal and sport mode?
It sounds louder but could just be me not noticing the higher rpms
Bacchanalia
Tony
Is there a way to have the camera turn when the front sensor warning comes on while in drive?
Tex
Cliff
San Angelo
I don't believe there's an option for that, but you can get a module to bypass the motion lock on the cameras and turn them on whenever you want.
jorgem31
Jorge
Tampa
I haven't seen that mentioned anywhere. Do you have more information?
