Forscan vs. 2022 Bronco
DaveR
PA
Audi
No it defaults to 4A but if you want you can turn it to 2H. I leave it for the extra traction.
if you select Baja and change to 4A or 2H, isnt that the same as Sport Mode? If so, no need to add sport mode in a Badlands via forescan.
RBT2583
Robert
2023 Bronco
I have set this already, blower starts running only after pressing the start button :(
Also having this issue. It’s cold here and would like to pre heat but like you said heat won’t come on until you push the start button. Would love to figure out the solution.
Winds of Change
Chicagoland
2022 Bronco Obx SaS/2021 Bronco sport Badlands
I did pretty good with my first crack at Forscan. I just did Auto stop, Added Sport Mode, Lost Double Horn Honk, Bambi Mode, Fog lights w driving lights. I could not figure out "Nav Control in Motion" or "Lose Fake Engine Noise through speakers". I am determined to lose the faux engine noise, which I am positive it has. Also I added all 4 windows up from remote which did not seem to work. No idea why I want that anyway. I will keep researching. Thanks.
With the Global windows did you make the changes to the 4 modules all at once and then cycle the ignition? Or cycle the ignition inbetween each module? Did you have to do the initialization/relearn and if so how is that done?
