2022 Forscan
Kamikazi_bronco
NJ
VW GTI
I have the version 2.3.47 test20220221, but I am still getting service interrupted error when trying to relearn pcm module. Any suggestions?
Forrest
San Antonio, TX
‘19 Ford F-350, ‘21 Cactus Grey 4Dr Badlands
This may be a dumb question but does anyone have a spreadsheet for the 2022 changes in forscan… I guess what I am asking is I change the * value to whatever is needed in the spreadsheet?
Herbie
Alex
Cleveland OH
2022 Badlands
I believe spreadsheet is current to February 12th or there abouts last time I looked. Yes * gets changed to value in the box written in at the right.
Forrest
San Antonio, TX
Managed to add Sport Mode and disable double honk however still can’t access IPC via forscan
Cysquatch
Adam
Rancho Cordova, CA
2016 CTS, 1996 Silverado 4X4
Normal mode does not alone engage 4A. You can be in Normal and then turn on 4A.
Skipping through the thread I noticed the Badlands/SAS doesn't have sport mode but my BaseSquatch does? That's kinda weird.
As far as 4A. If you start in sport mode and then switch to normal, the 4a will stay engaged. But yes, otherwise, you tap 4A if going straight to normal.
Herbie
Alex
Cleveland OH
2022 Badlands
I know that the sheet says that one can add remote start to their manual transmission vehicle. Can anyone on here confirm that they have done this? And if so, besides the forscan changes on the sheet (that are a little unclear at least to me) what else do you need, the proximity alert module with the little jumper wire installed?
ctandc
VA
'22/23 Bronco, 96 EB Bronco
Has anyone tried to do the Window Global close enable on a '22? I'm very familiar with FORSCAN from previous vehicles, so I'm pretty sure it's not a user error. I even ordered the 'recommended' OBD link to try vs the switched version I've used with zero troubles over the past 5 years or so.
I can make all the BCM changes, but it will not let me complete a write to the Door modules (DDM, PDM) to make the needed changes.
I even downloaded the latest Beta version and no dice.
Just wondering if anyone else has seen this? Not really a big deal. All the other changes I wanted worked fine (double honk, panic alarm, seatbelt reminder, speedometer calibration).......
mark2215
MA
2015 F350
I have global open/close working on my 22.
rabidmoravians
Jeep
Everything has worked for mine other than adding goat modes
ctandc
VA
Really?
I tried using latest full version of FORSCAN 2.3.47? Tried two different OBD adapters. Then tried FORSCAN's newest Beta.
Still won't let me write to either the DDM or the PDM for the Global Close change.
Did you change AS BUILT data or not?
You have a 4dr or a 2dr? Just curious.
What version FORSCAN are you using?
Thanks.
