- Aug 28, 2022
- 2
- 26
- 89
- Greenville, NY
- 2022 Ford Bronco
- Base
Not sure if others are having issues with changing codes using Forscan, but after about 4 rounds in the ring, I finally got all the information together, got what I needed from Forscan and it worked. You will need to purchase the license from Forscan. It's $12 for one year (and completely worth it to me). When you get the license, contact Forscan, let them know it's not working and they will send you a link to the Beta/Test version they're working on. It worked perfectly.
This is what I used:
OBD Adapter: https://www.amazon.com/dp/B081VQVD3F?psc=1&ref=ppx_yo2ov_dt_b_product_details
I did a firmware update on the adapter, that link is here: https://www.scantool.net/downloads/updates/obdlink_ex/
Forscan: https://forscan.org/download.html (then I went in and purchased 1 year license)
This is the code spreadsheet I used: Forscan Google Docs
I can only speak for the double-honk, door chime and auto start/stop codes. And please make sure you save a copy of your original setup!!!
I have a June 6, 2022 Base model build. Hope this helps anyone who has had issues changing codes on a 2022
