Forscan vs. 2022 Bronco
kimmiemom64
Greenville, NY
2022 Ford Bronco
Not sure if others are having issues with changing codes using Forscan, but after about 4 rounds in the ring, I finally got all the information together, got what I needed from Forscan and it worked. You will need to purchase the license from Forscan. It's $12 for one year (and completely worth it to me). When you get the license, contact Forscan, let them know it's not working and they will send you a link to the Beta/Test version they're working on. It worked perfectly.
This is what I used:
OBD Adapter: https://www.amazon.com/dp/B081VQVD3F?psc=1&ref=ppx_yo2ov_dt_b_product_details
I did a firmware update on the adapter, that link is here: https://www.scantool.net/downloads/updates/obdlink_ex/
Forscan: https://forscan.org/download.html (then I went in and purchased 1 year license)
This is the code spreadsheet I used: Forscan Google Docs
I can only speak for the double-honk, door chime and auto start/stop codes. And please make sure you save a copy of your original setup!!!
I have a June 6, 2022 Base model build. Hope this helps anyone who has had issues changing codes on a 2022 :)
kimmiemom64
Greenville, NY
2022 Ford Bronco
im not to computer literate , so how do you make a copy and where do you save it to?
Fortunately, Forscan is extremely user friendly and it will prompt you to save a copy and will place it automatically in your C: drive under the Forscan program. You can change where it goes, but I don't see the point.
I highly recommend you go to You Tube and search for 2022 Ford Bronco Forscan. I think I've watched them all. They go through and show you the steps on screen. Good luck and reach out if you have troubles!
bradcd
Brad
Saab 9-3
Just today I disabled the double honk on my 2022 Badlands. Fortunately I already owned an OBDLink MX bluetooth adapter so I did not need to spend any additional money beyond that. The double honk was pretty much the only thing I needed to adjust via FORScan. You can request a 2 month trial license for FORScan for free. Not necessary to purchase a yearly license if you only want to set something once or tinker for only a little bit of time. Here's a video that helped me, double honk settings at the end:
BottleShark
TJ
East Texas
Nautilus, Samurai, 12v Dodge, Fiero, Karma Ghia
I want to learn more about it, but I'm sure I would brick my Bronco, lol. I did the double honk delete and Bambi Lights with no issues.
AZ_Liberty
2007 Expedition
Does Bronco have auto locks like the F-150? That's the 2nd most annoying thing on my wife's F-150 (after the A/SS).
I figured on fixing her car and my Bronco once I got the Bronco.
kimmiemom64
Greenville, NY
2022 Ford Bronco
Good to know the OBDLink MX adapter worked so well and without having to get the latest and greatest Forscan. Unfortunately, the free trial of Forscan did not work intitially with the adapter I have. After digging in forums, I thought the firmware update on the adapter was necessary, still didn't work. Then I tried purchasing the extended license (again, only $12), which still did not work. It wasn't until they sent the link to the Beta version that I could change codes without the error.
Curious to know if build dates play into whether or not the free version works...
bradcd
Brad
Saab 9-3
I think I read on the forum here somewhere that it's the software version of FORScan itself that matters for 2022 MY Broncos. The latest version v2.3.48 (not Lite) worked for me without issue first try. Since yesterday was the first time trying all this stuff I probably bypassed the issues some people were having with their 2022's and earlier software versions.
XirallicBolts
Xira
Midwest, USA
2016 Flex EcoBoost, 2022 Silverado LT
They're still adding support for 2022, Ford must be making some changes.
2.3.47 had issues writing to DDM/PDM which was resolved in 2.3.48, though PSCM editing still has issues.
Snowdogyyz
23 Ford Bronco Wildtrak
I downloaded the latest version of FORSCAN and used theOBDlink and had no issues changing things on my 22 Badlands (March build). Didn’t need the beta version.
jwysopal
James
Los Angeles
2021 Ford Bronco Black Diamond
I've done some simple things with Forscan, add Baja, tire size adjustment, and double honk, but I haven't seen anyone show how to write your saved profile back to the Bronco if needing to go back to stock. How is this done? Thanks!
fallguy
Tennessee
2020 Defender, 2022 Outerbanks SAS, 1968 Mustang
I have a 2022, successfully have all GOAT modes now, disabled the double honk, and full range to the rear speakers. What I cannot do is get the damn auto start disabled.
Has anyone got this to work on a 2022? The number/letters I have look nothing like the tutorials I have watched. Tried to write it anyway... gave me an error at 56%. Everything seems to be working fine still though.
Kenny
Covington, KY
'18 f150, 18 gt350r, '93 mustang
I gave forscan my first try tonight on my 22 bad squatch. Got everything to work it seems. I wanted to add sport mode which I did and it shows up and works but my concern is that it is in 4A mode. Is sport mode supposed to be in 4a and not 2wd?
BigBendBW
Columbus, Ohio
Bronco Base Sasquatch
Yep, my Basesquatch goes to 4A automatically in Sport mode.
98infinity
Alberta
16 F150, 20 Road King, 22 Bronco
My stock 22 does this as well, just press 2wd and it will stay in sport mode
