Forscan vs Procal4 compatability
Tdecell
Trey
Clinton, MS
2004 F150, 2021 Outer Banks, 2022 Badlands
I've got Forscan and have done several changes to my Bronco, all worked well. I have a friend who wants to add "rock crawl" mode to his Wildtrack. He has the Ford Procal tuner installed on his Bronco. My question is this... Will adding the rock crawl mode to a Bronco with a Procal tune installed mess anything up with his tune? My thoughts are to put the Bronco back to stock configuration with the tuner, use Forscan to add the drive mode wanted, then re-install the tune. Any thoughts?
smonroe111
Stephen
Dallas
Chevrolet Tahoe
I found no issues when adding the ProCal to my 2.3 badlands.
GA2Dr
Marietta, GA
2024 Bronco 2 DR 2.7
I am not an expert, but I don't think any of that is necessary. I have a procal, removed eco mode and added Baja and that did not change the tune. Go ahead and add rock crawl
Tdecell
Tdecell
Trey
Clinton, MS
