Procal4 Tune with Pedal Commander
Mitch65
Mitch
Huntongton Beach, CA
2022 Bronco Badlands
Hi,
I have a Pedal Commander installed on my 2.3 2022 Bronco and it has increased throttle response fairly well. I just Did a Procal4 tune. Can I leave the pedal commander in place also without screwing anything up?
Thanks
Gotchaa
Los Angeles
Tesla
Not sure what you mean by screw anything up. The Procal tune adjusts the throttle in different modes as well. So Pedal Commander would be additive on top of that. I use it on a 2.7, I turn it off when I am off road. You can play with the settings to find what works best on street. I haven’t had any issues thus far with it and Procal 4 tune. Pedal commander just gives you finer manual control of the throttle response where the Procal tune has factored that all in the different GOAT modes automatically
Kach Vartan
Los Angeles
Sedan
I've been using the ProCal and Pedal Commander together for about a year. No issues whatsoever, it's just a matter of how sensitive you want the throttle control to be. As the previous post notes, the ProCal already makes some nice adjustments to throttle control over the stock set-up. Pedal commander gives you even more precision.
For normal day-to-day driving, I tend to leave my PC on the City setting, plus 2, and run either Normal or Sport GOAT mode. Also, if you enable the max Sport+ on the PC and Sport GOAT mode at the same time, look out!
Mitch65
Mitch
Thanks for the advice and sharing your experiences!
