What genius at Ford?
HoosierDaddy
__ Eric
NW. Indiana
Seems like you've never heard of longer tow bars, or extensions.
(^^^^ Posts picture that literally has zero context to his comment, other than typical B6G bro braggartry)
:wink:
Ford Bronco What genius at Ford? 1716741761581-
HoosierDaddy
__ Eric
NW. Indiana
Would love to see a picture of this. I am struggling to understand the problem. I cant imagine you wouldn't need some drop anyway given the height of the bronco. The trailer is supposed to be level to ride right anyway.
There is not enough room between the spare tire and the ball to get a normal trailer hitch under there with the locking handle in the up position .... unless you use a 3" to 4" drop hitch.
Something like that, I'll have to check what drop I ended buying for my factory Badlands on 33's ... might have been 3 1/4 and then it just BARRRELY cleared.
2" was a no go, had to put the spare in the trailer.
The same happens with both the base Base with 35"s (added) and the Badlands on 33's.
Another option might be to get a spare relocator bracket that raises the tire a couple inches.
Also, at whatever drop I ended up with, the trailer jack almost couldn't rotate down because it was so close to the ground.
pic of Badlands & 2" drop.... I believe.
Ford Bronco What genius at Ford? 1716742453276-7u
Best I have of the larger drop.
Ford Bronco What genius at Ford? 1716742569739-ud
Ford Bronco What genius at Ford? 1716742593337-45
Ford Bronco What genius at Ford? 1716742648514-7u
base suspension Base on 35's with 2" drop ?
Ford Bronco What genius at Ford? 1716743361635-9o
Fordified1
Bob
Mid South Texas
It’s not rocket science. Use your brain and. figure a work around. Extension or drop hitch or remove the spare. 1st priority with the design of the Bronco was not towing ability. I tow with mine with a 2” drop hitch just fine though. Every situation is different. My god when internet goes down some of us are doomed lol. Maybe shouldn’t be towing at all.
JohnnyBronco
Pennsylania
X4
What effin trailer manufacturer would sell a rig with a jack that sticks up 2 feet and is only 12 " from tongue? Folding jack
Wouldn't a drop down tailgate just smash into the hitch? On the F150 there is a bit more vertical space to accommodate the hitch, but with the lower load floor of the Bronco there is limited space.
I guess you would be able to crack the tailgate a bit, but that would still be really awkward to remove items from.
Drop down tailgate on Ranger doesn't interfere with hitched trailers
STLDAVE
Wentzville, MO
2011 4Runner
Idk what you are pulling but every boat trailer Ive towed with my Bronco has required taking off the tire so the safety pin doesnt hit the tire/bottom of tailgate
I'm confused. Does your safety pin go in vertically or horizontally?
Tacanta14
Wasichu
Pie Town, NM
2022 Black Diamond 4 Door 2.3 MT
:wink:
Are you saying that I posted a picture that has zero context to the OP's comment, or that you posted said picture? Asking for a friend.
SHANUT
Craig
Hermann, MO
I use the standard hitch with the common 2” drop…I would need at least a 4” drop to be fine but at that point the trailers will be pointing down which is a no no
I have a 6 inch drop and my utility trailer and my dump trailer both just fit under the tire and they both have a slight upward pitch to the tongue of the trailer.
Ford Bronco What genius at Ford? IMG_0025
Ford Bronco What genius at Ford? IMG_9553
AKBronc49
Russ
Anchorage, Alaska
I have a buyers adjustable hitch, works great on the Bronco.
Ford Bronco What genius at Ford? 20231217_131249
tourproto
Portland, OR
2004 BMW 330i, 2022 Bronco BL 4DR
This is what I put on my BL. Works fine. Found it at U-Haul for $24.95.
Makes pulling a boat easy-peasy.
no clearance issues at all with the standard spare tire. Will add a photo with the boat trailer attached if I can find one.
Ford Bronco What genius at Ford? IMG_3632
Here are some pics I found from last summer pulling a trailer with a river float rig. Again not an issue at all hooking it up. 2 min tops.
Ford Bronco What genius at Ford? IMG_9561
Ford Bronco What genius at Ford? IMG_9560
Ford Bronco What genius at Ford? IMG_9558
cbrenthus
Western PA
'22 BadSquatch, '02 T/A
Is it a One-up rack? I noticed the same lack of space, but I was able to sneak the pin up and over the 7 pin connector to get it in the hole.
no, it’s a kuat, and I think I’ve been able to get the pin in, but it’s way easier to remove the wiring bracket
RimrockPaul
Paul
Rimrock AZ
2021 Ford F250
Who the F### at Ford design the rear of the Bronco to make it f%%%%ng useless for towing unless you remove the spare tire every time
*I have factory tow package
Calm down cowboy. Most of us have no problems.
  • Like
Reactions: LCW
KJSnider
KJ
MN
2023 Bronco Badlands 2D 2.7
Now I'm intrigued...
How do you have room to put your pin in from the left side?? I just used my hitch this week in my new to me '23 Badlands with factory tow..
There is no way I'm getting a pin in from the left side. In fact, just today I had a new pin delivered that doesn't have the angle piece on it.
K
tourproto
Portland, OR
K
haha! It was a tight fit! My best friend bought me a locking pin. Because of the keyhole it needed to go in from the left side.
I can’t tell you the brand, but it just barely fit.
kodiakisland
Arkansas
I've nothing constructive to add, so I'm patiently waiting for the OP to post up a picture of what the problem is.
Ford Bronco What genius at Ford? 1716787826811-2i
