Southside_Ray
Ray
Iowa
2014 Ford Fusion
For me, eventually, a hiker/drifter trailer. Mainly my bicycle though.
Ford Bronco What will your Bronco be towing? image-asset
Schnabby
Tim
OC & JNLK, CA
JeepJL4dr,Raptor6.2,JeepJK2dr,M4Conv,65Must,74CJ5
A single axle trailer that carries either my two ATV's or a couple of kayaks and some gear.
tn3sport
Tennessee
Ford 4x4, BMW, Mustang, several adventure bikes
what will I tow?
Bowrider, Waverunner, motorcycle trailer and... yet to be purchased: a light weight overland trailer.
Like campers, many overland trailers are overbuilt with accessories that jack up the price, size, and weight. I'll likely build custom or find one that is < 1,500 pounds. Only accessories I need are battery, genset, eCooler, water tank, interior bed (no RTT), and MTB mounts. Keeping gross tow weight down and trailer width narrow will be optimal.
Lakelife36
Ben
Interior of BC
What’s wrong with a diesel? More more efficient in every way possible over a gasoline plus more torque. So you can pull the house off the blocks if need be?
There's nothing wrong with a diesel - I'd love one with the 7M same as you. The powertrain is not what governs towing in this vehicle though.
Wizard1183
Lafayette
2014 Sierra/ 2010 Camaro 2SS
This vehicle has the towing capacity of a geo metro. An aluminum trailer and boat/ jet skis, or steel trailer with an ATV is about its max which is odd considering it’s solid axle. Should’ve gone with a Dana 60 at minimum with option of Dana 80
Buckin Bronco
ChoSunJuan
Canada
2004 Nissan Xterra
I kept the rear axle and leaf springs from my 2004 Xterra, I'm going to build an offroad camping trailer around it. I'm going to try to keep the weight under 1500lbs unloaded. Fully loaded, no more than 3000lbs.
AZHUND
2020 RAM 1500 5.7L 4x4, 2018 Wrangler S 3.6L
Same setup as with Jeep - but am debating not even getting the tow package and using my truck as the sole tow vehicle… and maybe upgrade to something bigger.
Ford Bronco What will your Bronco be towing? 47E03FF0-6F6B-4B84-B7DB-CC3DE3B0DEBE
2Jeeps&PatriotX1
Denver, CO
what will I tow?
Yes it definitely adds up quick. My offroad trailer is 2200lb dry and comes in at 3390lbs w/ 400lbs tongue weight when fully loaded.
