Coosguy
Phil
New Hampshire USA
Bronco outerbanks
I have never seen where Ford has said that? Pulling it out of a ditch is a lot harder pull than towing it down the highway in neutral
WIDirtFishing
WI
2018 F150 Lariat 2.7
So we hear all these horror stories about flat towing, why? Like what is the issue? Genuinely asking as I explore possibly getting a RV.
Is it people not following the instructions? Is it a 2.3 vs 2.7 issue? 4x4 Advanced vs Non-Advanced?
Coosguy
Phil
New Hampshire USA
Bronco outerbanks
It’s people making mistakes, and not taking responsibility for them either because they do not know what they’re doing or just ? Can’t admit that they have made mistakes.
userdude
Jared
Denton, TX
2023 2dr Badsquatch
There's a thread somewhere about it, but the consensus at least after a while was 4A made it more likely to explode the transmission. I think all or nearly all of the reports on 6g were equipped with 4A.
zuke
Stafford VA
Seems like all confirmed cases are 4x4 Advanced, I Don't think manual or auto makes a difference, Primary cause almost always seems to be the Bronco's battery dyeing, and the TC dropping out of Neutral Tow mode when it does.
Most people have mitigated the possibility by running a Charge wire from the Coach to the Bronco by now, and likely why we don't hear so many new horror stories.
Coosguy
Phil
New Hampshire USA
Bronco outerbanks
If you flat tow your Bronco the transfer case must stay in neutral, there is a simple process to put it into neutral, ”tow mode”, it is shifted by a solenoid and kept in neutral mode by this solenoid therefore you should have a towed battery charger such as the one offered for sale by RVI, you can monitor it from a tablet inside the motorhome. This will prevent the battery from losing power and the solenoid powering down. It’s really more simple than it sounds.
Fordified1
Bob
Mid South Texas
No it’s not. And I HATE when people say this without proof. It’s likely a software glitch that Ford has since fixed . Only failures I’ve seen in the forums were Broncos with the 4A transfer case, and most of those had towed many miles before without issue, and always followed the very clear easy to follow instructions. It clearly tells you when it’s in flat tow mode on the screen if you did it correctly.
Ford is never going to admit they were at fault because it will cost them millions in claims. There were even some Raptors that burned to the ground, and were denied warranty. One took the MH with it…Just that one claim would probably have been worth close to 1m.
Because of what I deduced from reading the forums about this since 2021, I bought my Bronco without the 4A system. Do I Still worry a little? Of course.
If my wife had been good with getting the manual shift transmission, that’s the route I would have taken, and rested easy knowing even if the transfer case shifted itself back into gear, it probably wouldn’t hurt the std transmission in neutral.
Fordified1
Bob
Mid South Texas
And if that solenoid gets weak or fails and takes out the transmission, Ford will not accept responsibility for the failure. Why are you taking Ford’s side on this? Knowing they have a horrible record of denying claims.
Fordified1
Bob
Mid South Texas
And nice to see @Ford Motor Company here, funny they're missing from the my tranny exploded threads.
You lost a transmission flat towing? Edit: sorry I re-read your post.
Taking it out of neutral tow is easy. Push the ACC button without starting it, hold the brake and put it in park. Then start it and see if you still have a transmission lol
dgorsett
colorado
F250, Mustang, Explorer
No no I didn't lose my tranny. I was trying to make a joke about Ford Bot being on this success thread and absent fom the failure threads.
And yeah, procedures are easy enough, but since I look at my cheat sheet every tme my mind kinda blanks if I just try to wing it.
Sojourner
Southern Maryland
2024 Bronco Badlands
Kansas to Riverside, CA., Kansas to the Canada border in North Dakota, Kansas to eastern Kentucky, Kansas to Hatch, New Mexico, Kansas to Colorado 2x.
2.7 Black Diamond automatic. We followed the printed out procedure to engage and disengage Tow Mode EVERY TIME we engaged or disengaged.
We have the procedure printed and enclosed in a plastic folder sleeve.
By the way, we live in Kansas.
Ford V10 powering your RV? I'm interested b/c I wasn't sure our Class B with the V10 could handle a full-size Bronco (we currently flat tow our very old Escape which is almost 1000lbs less in weight).
tfrazier
Tony
South Carolina
23 Bronco BL 2.7, Lincoln MKZ, Newell Coach (RV)
We are 5 trips in over the past year. Multiple in and outs of Neutral Tow and I have a 2.7 4A. No issues. For me, the check list is critical. Just the way my old brain works. I created one from the OM and modified it by adding pictures, circles and arrows. It is laminated and stays over the sun visor.
I use a full Blue Ox set up, with Demco’s Airforce One break system.
John W
Ivins Utah
24 Bronco Raptor
I'm in the middle of our first trip towing the Braptor, about a thousand miles so far. Its a blueox base plate and towbar with a 10" Gen-Y drop hitch to raise receiver hitch to bronco height. During one segment of the trip the Battery connection failed and we a arrived with no power in the bronco at all. Took it the dealer and they fixed the connection. As far as towing goes there have been no issues. I just follow the procedure to go into tow mode and everything seems fine.
dgorsett
colorado
I'm not who you posed the question to but: I have a 27' Class C w V10. All good, can do 50 up most any Colorado grade. Our current 2018 has the six speed which I would say is vital. Our old 5 spd, albeit a V8, would bog or over rev.
Tilzbow
NV
GM Sierra Diesel Pick Up
I’m curious: apparently you were pulling the fuse as an extra precaution. What was it about the software update that made this extra step unnecessary for you?
Brake boost would remain on for a period of time then shut off making supplemental brake systems over brake at the beginning or under brake after it shut down. Pulling fuses disabled brake boost as does the new software when the rig is placed into flat tow mode.
