Turn Offroad Portals
Rkgzx9leftcoast
Robert
Scottsdale AZ
Jeep JL
So forget the portals, if one was to just run some beefy 37x13.50r17 tires with like 17x9 -12mm offset wheels and a Dobinson MRR or any other lift kit. If you wanted to upgrade you gear ratio would you choose the 5.13 or 5.38 gear ratio? Stock setup is 4.7 with Sasquatch.
Ive been running 37s on mine for 4 years now, First with stock Sasquatch suspension, then with Bilstien 6100s and a Zone level, now with pro-comp coils set to almost the same height front and back as with the 6100s. Stock rims, I have the 2.0 rack with driver side bushing and upgraded to the Vasher design billet passenger side rack housing. ( have JKS tie rod sleeves also, going to upgrade tie rods now)
I have done some tougher trails, not as tough as Sierra and others, but the LCG and good upgrades you can wheel some tough trails. I would ditch the 13.50 wide for 12.50 wide though, beyond clearance issues, the 13.50 is a big tire and will add to tax on the steering.
4.70 gears are fine with the 10 speed, maybe you give up a little off the line , but the mechanical strength of a 4.70 pinion compared to a 5.13 or 5.38 will pay off in the long run.
zuke
Stafford VA
Just replaced our steering rack on the trail. Can confirm that the tierods are easier to change than the entire rack. Who knew?
If anyone is curious on how long it took-84 minutes start to finish. Including unloading tools. We’ve swapped a few of them but also took the time to clean the tierod threads with a pick. Your results might be better…or not…
84 Minutes! Wow, just took me 4 hours in a shop with a lift and helper....You're getting way to experienced at this
SierraBronco
This isn’t a good thing. You should see how fast I can tear the front suspension apart
NDM_84
Nedim
Richmond, Virginia
Camaro SS
What do you think about 17x9 wheels at -12mm offset instead of 17x8.5 wheels at a 0mm offset? I want to run a 13.50 wide tire in either 37 or 38 and don't want to rub internal components. Most of these aftermarket coilover lift kits require a 4.75 backspace on a 17x8.5 wheel which is a 0mm offset and if you do a 17x9 wheel the 4.75 backspace would translate to a -6mm backspace but the Method wheels I want only come in a -12mm offset and I want to run 13.50 wide but not sure if this setup will work. I do plan on the JKS clearance kit and aftermarket rock sliders that have better clearance. Also not sure if this is too much negative offset for 3.0 rack as stock is +30mm offset so I would be going a total -42mm offset which sounds like a good amount.
NDM_84
Nedim
Richmond, Virginia
Camaro SS
She's done! So far drives amazing. Went with Method 709HD 25mm offset and 40x13.5x17 Yokohama Geolandars. Loved the same tire in 37's and they are surprisingly light.
Wow that looks absolutely amazing man. What size wheel is that? Please post more pics from every angle possible lol.
SierraBronco
Looks good!
When you get a chance measure the width from the outside of your tire tread and report back to the thread 🙏🏼
I am curious why you went +25mm offset instead of +45 or +55.
NDM_84
Nedim
Richmond, Virginia
Camaro SS
Looks good!
Also, If you get a chance can you please measure how much tire poke you got beyond your fender and how much vertical gap between the tire and the fender you have now.
Dtrimpi87
2024 Bronco Badlands Sasquatch
Thanks! They are 17x8.5 +25mm wheels.
I'll be going out to get more pics hopefully tonight or tomorrow.
Dtrimpi87
Looks good!
Thank you! Leagues behind your rides but coming along.
Outside of tread to outside of tread is about 85.5". Outer side wall to side wall is probably about 87.5 with eye balling.
For whatever reason Turn syas they dont recommend any higher positive offset than +30. The only deciding factor with choosing +25 is because its the highest positive offset these particular wheels came in. I was originally just going to run my stock +30 sasquatch wheels but wanted to switch it up.
NDM_84
Nedim
Richmond, Virginia
Camaro SS
Looks absolutely amazing I'm glad you went with the 40s, that was a good call, if youre gonna go with portals might as well go with the 40s.
NDM_84
Nedim
Richmond, Virginia
Camaro SS
If you wanted to do 17x9 wheels instead of 17x8.5 does turn off-road recommend a specific offset in the case of running 17x9?
SierraBronco
That’s impressively narrow. You could get some longer a-arms and really step up the performance
Dtrimpi87
Tire poke is 3.5" front and 3" rear.
Vertical tire and fender gap doesnt say much as it will all depend on where you have your suspension set at but im right about 8.5" front and 9.5" back.
