Turn Offroad Portals
NC_Oak
2024 4 door 2.3 sasq
I see these are available for pre-order. No information on warranty has been posted. I know someone on this forum had a leaker (or a picture of one).
I've reached out to Turn regarding warranty. Specifically how they would compare to 74weld's warranty.
Will update if I hear.
PWillette
Parrie
Maine
I remember seeing a leaker posted somewhere. @SierraBronco may have some input.
SierraBronco
Somebody posted a picture from UBB on one of the other portal threads. I don’t have any details on these.
NC_Oak
Update on warranty - from Turn, I also subsequently asked about replacement part availability:
We are working on the warranty form now, should be on the website next week. But basically this is how it will go.
2 year warranty on all wearable parts. Axles, bearings, seals etc. If they wear out within that time frame we will send you replacements.
Lifetime on structure. Billet cases, brake lines non wearable parts.
PWillette
Parrie
Maine
Hopefully they use the good loctite
NC_Oak
They plan to stock (not make to order) all replacement parts. Per Turn.
I'd suggest they use Vibra-tite products instead of loctite but I'm partial to our own products :wink:
Turn Offroad
Cole
2021 First Edition
Hey guys, regarding the "leaker" photos circulating. We were still in testing phases during that and determined we need one additional O-ring to keep the fluid from the differential from leaking out on the rear portals. The boxes never leaked, just the fluid from the axle.
This issue has now been resolved! This is why we test!
SierraBronco
I read “leaker” like it was a sneaky picture taker of an unreleased product 🤦🏼‍♂️
NC_Oak
I daily mine but i have a few other vehicles. If they ship at the end of June as Turn's website states, I'll install them in July. although it also says estimating 15 days to ship.
I'll bring yall along for the install and test ride
NDM_84
Nedim
Richmond, Virginia
Camaro SS
My concern is that the wide scrub radius steering has not been fixed with these portals. The track width is the same as 74weld portals but no Hoss 3.0 reinforced steering upgrade, which a recipe for a failure. These portals only work with hoss 2.0, not hoss 3.0 steering rack, this is an issue for me. Why arent these designed to work with the Hoss 3.0 steering rack? I dont think upgrading only the tie rods is good enough when running 38s or 40s, you need an upgraded steering rack option just like the stage 3 74weld steering rack.
