Show me your knob.
swamp2
I copied the location I found here in another thread, flush mounted in the open rectangular area on the right end of the light switch panel.
Smokewagun
Bob
Northern Illinois
2024 Ford Lightning
In the glove box. Out of sight, out of the elements.
1st 75th ranger
jeffrey
nj
glove box ...0 issues
i marked mine after installer set gains ..so if i change bass for top off i know where to put it back to with top on
HeliPilot
Kenny
CT
2022 2.7L SAS
Not at my bronco currently, but mine is mounted left of the power window switch on the center console. Easy to adjust without ever looking down for the knob.
Jazer
Jessica
2.7 OBX
Ford Bronco Show me your knob. 1000001799
Virtually out of sight and within easy reach. I adjust mine fairly regularly depending on the song or type of music I'm playing, so I wanted it very accessible from the driver seat.
OVRLNDR
BLM
Can you share how much of the center console had to be disassembled to do that?
KABQ
Aaron
Albuquerque, NM
I found where to not mount it. Super convenient to reach and install with sub under the seat, but I kept kicking the cable out while getting in.
Ford Bronco Show me your knob. PXL_20240928_183221717
Porque No
San Antonio, TX
2006 Hummer, 2001 Viper, 2011 CTS-V, 2022 Bronco
To the left of the center console.
Ford Bronco Show me your knob. IMG_0473
Jack D
Jack
Central New Jersey
05 Jeep Liberty 6MT, 93 Explorer 2dr 5MT
Taller inner knob is for bass level, shorter outer ring is for fader. Professionally installed. You may need to modify or replace the Kicker knob housing.
Ford Bronco Show me your knob. IMG_4366
Ford Bronco Show me your knob. IMG_4368
Johnny Mo
Westchester County, NY
teachu2shoot.com
Mine is in the same spot - ZERO disassembly - you can route wires under the carpeting and behind there with no issue and then wedge the loose wire in the gap and behind the panels once ready to finish.
Ford Bronco Show me your knob. PXL_20240309_151452381
