Bass knob location for subs
edgeflyer
2013 FX4
Need to get a new one that's not all scratched up, but...
Ford Bronco Bass knob location for subs 20220329_121730
margareedaville
'22 Wildtrak
Here's my AudioControl ACR-3
Dammit I wish I would’ve seen your post here on how you did the AC3 knob. I installed mine with the lights in the same spot, but now I regret having the lights and I like the way you centered everything. Your ass looks way more pro. Great job! Now, I want a do-over!
Broncory
Ga
2023 Bronco 4D SAS
I installed mine on right hand side of dimmer toggle.
Sorry , long shot here. I know it’s an old thread. I’m assuming you ran this to a sub amp in the rear cargo area. If so, did you run it up the passenger or drivers side? It warns of interference, if running it parallel of any power wires. So I was curious which side you chose. Installing mine as soon as my complete kicker key system arrives in a few days.
alfiefmc
Alfie
Dallas
21 Badlands
Correct, amp and sub are in cargo are. I ran all the wires through driver side panels. I don't get any interference, but I have always used my same guy to instal and he wraps all the wires using black tap, maybe that helps with the interference. I hope this helps.
Broncory
Ga
2023 Bronco 4D SAS
Thank you
mdube72
Matt
NH
Audi SQ5
Under the steering wheel - stealth location, easy to adjust and no holes visible to anyone. Plus Ford gave us a nice little square cut out to poke the wire through :muscle:
Ford Bronco Bass knob location for subs IMG_1871
Ford Bronco Bass knob location for subs IMG_1872
EOD98
Las Vegas
2025 Bronco Badlands Sasquatch
@mdube72
I like that spot! Wouldn't have to drill any holes or worry about replacing any plastics if I upgraded/changed my system and didn't need the knob any longer. I have my redarc trailer brake switch in the headlight switch area already...
23OBX2.7
AB Canada
2023 Bronco
@mdube72
It's kinda awkward unless GF adjusts it for you haha I find that two way tape on the bottom of HVAC console face facing floor console is out of the way and easy.
23OBX2.7
AB Canada
2023 Bronco
