Second failed transfer case
Beach_Bum
Ken
St. Augustine, FL
2023 Outerbanks Bronco
Sorry for your trouble & hope they get you fixed before too long.
Here is some good info for those following the thread 🤠 .
Thanks for sharing that video. To piggyback on his supposition that it was the tow on the front wheel dolly that smoked the clutch pack, there was a long running thread here on B6G that dealt with a FE that had the same issue. The Ford tech was putting it on the owner for driving in 4A when in reality it was the issue that it was towed in 4A as the system doesn't shift out of 4A after being turned off.
Edit: My screenshot earlier in this thread was from the aforementioned video where the Ford tech was putting the blame on the owner.
popo_patty
Caleb
Sacramento
2021 Bronco/1996 Jeep XJ/1957 FC-150
I will hold the camera?
I’m down to help. I’ve been meaning to check my driveline as well anyway as Ford keeps telling me it’s not needed till 100k which I disagree with. I asked them to check my fluid at the last oil change which they said they did. Funny cause my chalk marks didn’t budge… funny how that works.
Felix808
SRV CA
Don't ever follow Fords extended maintenance time lines. They want it to break so they can fix it or sell you a new one. Oil is cheap considering the price of replacement $.02 🤠
Natai
Sean
Sacramento
Nissan Sentra, Mercedes GLC
@popo_patty would also be a good candidate!
That's exactly who I was going to recommend. I reached out to him on FB and he linked me back to this thread. So looks like we got him from both angles!
Felix808
SRV CA
@popo_patty there's no escape for you famous YouTube guys :p
HoosierDaddy
__ Eric
NW. Indiana
It's the RTR grill !!
It has to be the RTR grill !!!
It's like waxing the MIC .... makes the honeycomb pop out!
RTR grills make the transfer case puke!
MLRey
Lancaster, CA
21 Ford Ranger Lariat FX4, 18 Subaru Outback
You should see if the dealership technician will give you the data readout from the computer. I'm sure there's more data available than the simple 4x4 system fault message. With a high end scan tool like the dealer will have you can read much more than the simple OBDII codes. There might be some useful information about what was happening with the system when it failed.
Rivers90
Ben
Southern California
2 Door Base Sasquatch
It’s the Advanced 4x4. Having some regrets about that now 😑……
Ya the advanced 4wd is too advanced for it's own good.
There are posts of where the advanced 4wd stops working partway though a trail so you only have 2wd but then randomly starts working when on the pavement.
Simple but reliable would be my choice.
Kickit
Kickit
I wish it WAS the RTR grill! Would have saved me a long phone conversation with ford customer service and the embarrassing admission that maybe I shouldn’t have bought a first model year vehicle 😩
mpeugeot
That is allegedly the stronger transfer case...
I don't think that we can blame the RTR grill, but that might not stop Ford from trying. ;)
BTW, I have 90K miles on my advanced 4x4 transfer case and I have not been gentle to it (nor have I abused it). It is an early 2021 in the 2.7 engine hotzone.
flip
Phil
IN
www.ruxerparts.com
Fords
When the repair is finished OP should get a copy of the invoice which should include the technician writeup. It will likely show what the failed (causal) part is and provide clarity, this is also what Ford sees when it's submitted for warranty reimbursement. If not, the OP can give me their VIN and I can check the warranty history (after Ford pays the claim) and verify what was done.
Although I don't have numbers to back this up, single, much less multiple failures of the same component, is rare. Not accusing or suggesting this but the first assumption that's made after same component failure is usually driver induced. There're so many factors that can impact this type of failure (internal components, overheating, outside damage, multiple modules and control systems, sensors, etc). The possibility the repairing tech is able to say with 100% confidence what happened is not likely to happen. Ford expects us to identify the causal part when doing a repair to make sure what failed is first, warrantable (AWD module going bad and causing transfer case to shit the bed may not be covered if the module is only 3/36) and second, make sure it is the only cause of the failure so they won't be on the hook for a subsequent repair .
The more systems and complexity of those systems is making it a lot more difficult for techs to properly find the root cause. We've had engines preform rapid, unscheduled, disassembly, perform what failure analysis we can, then be given grief on the claim because we couldn't say for certain if a rod broke first, it dropped a valve, fuel injector stuck open, piston split or something else. Claim got denied and we had to go round and round with Ford for months to get it paid.
The only hope in this situation is the internal damage was extensive enough to warranty replacing the assembly in order to eliminate the possibility of a missed internal anomaly.
NorthShoreBronco
Steph
Canada
www.youtube.com
21 Badlands 2D, 22 BD 4 Door
I blew up one of these cases in my old ranger. I work at the dealer so we opened it up. I'll see if i can find the pics.
What happens with these most of the time in snow or ice, is that the tires spin, then abruptly make contact, coming to an abrupt stop and shred the gears like butter. The tech write up will most likely just say internal failure.
Not saying this is what happened to you. That's what I did..... and what most that we see have done.
