Second failed transfer case
Kickit
Kickit
For the snow did you have the lockers engaged ?
Front & Rear ?
I only have the rear lockers on my non SAS black diamond, but I did engage them as soon as I realized the wheels were spinning
Zulu7
high desert
Broncos & Bikes
Well that’s gnarly. So aside from trying to avoid spinning the tires how does one avoid doing this?
If stuck in snow I'd go 4-Low and engage both front & rear lockers. Then not too heavy on the gas as @Brian_B mentioned
Oh, no front locker. And you did engage the rear locker
Maybe 4L would help too
broadicustomworks
Hanging Rock, North Carolina
vrtical
Doug AI
GSMNP, TN
Fords
4H in the bronco in snow at higher speeds sounds like a time bomb, seeing a bunch of failures reported over the last week whether its spitting the FDU out or transfer case. Me thinks 4A (or slower at 4L) would be a better choice since it uses the clutches.
Felix808
SRV CA
Now if only there was some kind of setting for such instances like a GOAT mode or something that would decide what is best to take some of the guess work out of the equation :unsure: (jk).
Kickit
Kickit
🤦‍♀️ fully kicking myself for not using the GOAT modes. I think part of me just brushed them off as a fancy gimmick. Guess I know better now 😜
we can all laugh at me because I’m definitely laughing at myself *
* only because it’s being repaired under warranty
vrtical
Doug AI
GSMNP, TN
Fords
On a side note, that does help with certain things, but ya know owners don't read the manual. Point in fact, if you put a brapter in baja mode it reduces the sensitivity of the air bags which I thoroughly tested 😂
Felix808
SRV CA
That's a good thing. A guy here was at Pismo (Oceano Dunes) back in Oct that tested out his drivers air bag. Turned out to be a $2K experience :sneaky:
Silver-Bolt
Bill
Eureka, MT
Were you in 4HI or 4A? Snow wheeling is hard on rigs, but it's usually the transmission of cooling systems that have issues.
Felix808
SRV CA
Sorry for the salt & thankfully they are covering it for you (y).
I always try to take the attitude of a guy I use to know. He would always say we are going to laugh about it someday, might as well start now. That guy tore up some equipment $$$$$$ over the years :rolleyes: .
Like I said I try but don't always succeed :sneaky:.
broncobase1
Lincoln
22 Bronco Base
I was on about a year ago with the exact same issue after driving in the snow. Was five miles out and had a transfer case failure. Well last week I was on another snow run, 4h (no, not on pavement) and when I got home I noticed a rotational clunking noise when in 2h. Took it in to the dealer (praying it was just the CV joint or a torn boot) and it’s the transfer case again.
For reference I have a 4dr 10spd 6cyl black diamond, non SAS. Zero aftermarket upgrades except the RTR grill. Just curious if anyone else has had the transfer case fail more than once. Fortunately they extended my warranty last time.
I mean I’ve really put this thing through the paces, white rim trail in Moab, unimproved BLM land through Nevada, hairy roads in the lost sierras, and then one time in the snow I’m out a transfer case again?
seeking advice or reassurance. I’ve thought about asking for a buy back but with the current auto loan interest rates and increase in vehicle prices I’m loathe to have to be in the market for a new car.
Are bet this is the Advanced transfer case? This is one reason why I'm not interested in the Sasquatch package. The standard transfer case is just a gear box, unlike the complicated advanced unit which has clutch packs.
Zulu7
high desert
Broncos & Bikes
🤦‍♀️ fully kicking myself for not using the GOAT modes. I think part of me just brushed them off as a fancy gimmick. Guess I know better now . . .
Ehhh . . . GOAT modes are overrated - mostly a mirage
There's no GOAT mode that defaults to 4-Low with both lockers engaged.
The "Slippery" mode does give you reduced throttle response which is handy on snow, but it defaults to 4A with no lockers
You were doing pretty well. Just select the 4WD options you need a la carte
Big trouble with GOAT Modes is remembering all the defaults & the options each Mode allows/prohibits. You're talking several pages in the Owner's Manual
mpeugeot
And all those defaults & allowed options for each GOAT mode also depend whether you have Part-Time 4x4 or Advanced 4x4 transmission. Trying to remember all that info in a pinch is ridiculous
Eh, it's not as hard as all the hundreds of citations I had to memorize to successfully complete my Ph.D. advancement to candidacy testing. ;)
