Rusty Driveshaft buggin me
MDH
Southern California
2017 mazda6
Ok, I know minor surface rust on the powertrain and frame is common and not a problem. But my driveshaft is completely coated in surface rust and it’s driving me and my OCD crazy. I’m thinking of just soaking a rag in WD-40 and giving it a rub down. Would that do any harm? Anyone have any better idea?
MilesTeg
United States
2024 2DR Badlands Manual/VB, 2018 F-150 Lariat/3.5EB, 2013 Mustang GT DIB
My understanding, which could be wrong, is it's pretty easy to unbalance a drive shaft if you start sanding or otherwise removing material from it. They spin very fast, and even slight deviations can cause trouble.
I would definitely seek more advice before doing anything. You could turn a cosmetic issue into a mechanical issue.
I also might be misinformed about how easy it is to happen, but I thought I would say something.
Area51BS
Ron
Badlands non SAS 4dr 2.3
Eastwood makes a good paint to go over it. Shouldn’t unbalance it much more that a little mud
  • Like
Reactions: MDH
Q1svt
Sunny & Warm SoCal
2025 Badlands, Sas-sy Manual 2dr, # of fords
… might want this… will last longer.
Boeshield T-9 is a premier waterproof lubricant and rust preventative developed by Boeing for long-term metal protection. Good on most things… picture is a 14 year old motor sprayed since new
This will kill the rust but will need something afterwards… T9, clear coat, paint
EVAPO-RUST
  • Like
Reactions: MDH
Lifeliberty
Moonbeam👀
Columbus, OH
I've used rust bullet and it works great on rust. But I haven't used it on driveshaft. It can be thick, so I could see balance as a concern.
I've also used evaporust, which works surprisingly well. But it more eliminates rust, it's not a protective coating
  • Like
Reactions: MDH
dgorsett
colorado
F250, Mustang, Explorer
IDK but Rusty Driveshaft would be a great country band name.
