SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
Question: Can I add just the bracket to a factory SAS Badland Bronco and gain improvements? OR do I need to add an adjustable bar as well?
This is a previous answer that I posted on another thread talking about ride height, stock application the benefit of an adjustable track bar as well. I begin talking about height...
So, the height of the lift does matter - because if you are lifting it maybe 1.5 to 2.5 inches from stock height then the bracket should/may suffice (but it won't necessarily be perfect). Any higher and I would highly recommend an adjustable track bar. Think of it this way......at the left of the track bar it CONNECTS to the body of the Bronco. The right, opposite end, of the track bar connects to the right-most part of your axle. The connection points are NOT in the center. As shown in the pic below:
Ford Bronco Rear TracBar Relocation Bracket - Get One! img_7287-
For a proper comparison - The Ranger Raptor has solved this issue with a center-link system. Regardless of how high or low the travel of the axle it always remains centered and handling/geometry are not compromised. Very cool tech I might add, shown below:
Ford Bronco Rear TracBar Relocation Bracket - Get One! ranger-track-bar-jpg
Now, back to the Bronco - Let's say we REMOVE BOTH the rear control arms and rear shocks that are attached to the axle - and the ONLY thing connecting the Axle to the vehicle is the track bar. With the vehicle on the ground, if King Kong (for lack of a better example) were to lift the body upwards, as long as the wheels remain on the ground, they should remain centered in the same spot about 25% of the way up. But the track bar will keep exerting more pulling force the higher it goes - wanting to DRAG the axle to the left. A relocation bracket LIFTS UP the connection point on the axle, correcting geometry and actually improving it by "delaying the angle-rise of the track bar." As seen in the pic below:
Ford Bronco Rear TracBar Relocation Bracket - Get One! img_7290-2-
What this also accomplishes, is it spreads the lateral loads more evenly - meaning left and right movements (pulling to the right, pushing to the left) as the suspension goes up and down. This translates into better handling since the forces travel a shorter distance and are on a more level plane. This is felt through better steering inputs (road/trail feel). It is thus better, but not necessary, to have an adjustable track bar as well - so that a proper alignment shop can dial in the perfect length the track bar needs to be at, depending on your lift.
I hope this explanation helps clarify things :thumbsup:
BoverW
J
Socal
I was wondering if Boss or any of these other manufacturers quote measurements (of adjustment). Eyeballing my sasquatched Big Ben, which has a little bit of weight added to it in that I have added steel skids and what not, I estimate it would take an inch or an inch and a half of rise to get the track bar level. Thus, I think most of these relocation brackets would be too much. I need to crawl under there and do some measurements to find out fer sur...
Edit: does anyone sell an "adjustable" track bar relocation bracket?
ARB might be lower than other options.
SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
(@bmiller too) I think a good rule of thumb would be to go to your trusted alignment shop (that does or specializes in off road vehicles) and have them check it out. They should be able to give you some good advice. Technically, the higher up that connection point on the right is (on the axle), then you would need to shorten the bar. This is also why it is good to have an adjustable track bar and not just the bracket.
Poppavein
Redmond, WA
Harleys, Ducatis, 2024 Bronco
The Fabtech bracket looks beefer than the Rock Jock bracket. Made of 1/2" steel vs 3/16" of RJ's and It adds a gusset brace, wraps around the axle mount with an extra mounting bolt. Don't know if its necessary but looks heavy duty. Keep us posted on how the install goes.
IIRC, Fabtech states their brackets are for 3+” lifts, RJ states for 2+” lifts.
Badsquatchman
Brent
Maryland
motorcycle & 93 Z28
In the picture below, the rear suspension is lifted approximately 2.5”. With the RJ bracket my stock tract bar is nearly perfectly level. In this photo there’s about 200lbs of gear in the rear storage area.
Ford Bronco Rear TracBar Relocation Bracket - Get One! IMG_1193
B Miller
Sherwood, OR
Perfect. Thank you for the info!
WheelMe
Patrick
Northern California
2022 Bronco Badlands Sasquatch 2.7L
Do you consistently have the 200 lbs. of gear in your rig? I'd think that you would adjust the track bar/bracket setup to conditions that you most frequently find yourself in - in my case, zero load except a Ford Accessories metal drawer in the trunk full of recovery gear... totaling maybe 60 lbs.
Badsquatchman
Brent
Maryland
motorcycle & 93 Z28
Normally about 100 pounds (this includes the extra weight of the 38” tire and gate brace) loaded it up before I took this photo. Appears to ride about 1/2” ish lower with the extra weight. I don’t have an adjustable bar & the bracket is fixed
orion
Jeremy
17' F-250, 17' Explorer
Got the FabTech one installed. It raises the track bar up 3". Hopefully I don't hit the frame under full compression. Will test that out...
Ford Bronco Rear TracBar Relocation Bracket - Get One! 20241209_074330
Ford Bronco Rear TracBar Relocation Bracket - Get One! 20241209_112239
SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
Sweeet man! That looks GREAT! Looks like you also have the RJ Control arms and Trac Bar. Noice!!!!
Man........that diff cover is sooooo sexy. I want one so bad but don't think my DV8 diff skid plate will fit it. UGH :(
lethalchristy
Christy
Wellington, FL
www.lethalperformance.com
2021 First Edition, 2013 Mustang GT
Installed the RockJock bracket w/ RPG bar this weekend. Came out 👌
Ford Bronco Rear TracBar Relocation Bracket - Get One! IMG_8965_jpg
SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
lethalchristy
Christy
Wellington, FL
HOLY SEXY trackbar Batman!!!!!
Haha it is quite the beast, however I do wish it was adjustble while installed. Que sera, sera I guess.
IwannaGOfast
Jon
Brea, CA
2021 4 door Badlands, 1991 Ranger Long Travel, 2014 Cruze Commuter
I highly doubt it is made from 1/2" steel. It would be way too heavy and completely overkill. It looks more like 1/4" plate.
orion
Jeremy
It is indeed 0.25 inch!
