PPE Transmision Pan installed
Ducati1098
Do you happen to have or remember the torque specs for the pan bolts and the filter bolts? Those pages won't load from the service manual that was posted here on B6G. Only the drain/refill section loads and that only gives the fluid fill plug spec (35 lbs. if anyone needs it).
Better yet anyone have the transmission pages from the service manual?
307-01 Automatic Transmission - 10-Speed Automatic Transmission – 10R60
2022 - 2023 Bronco
Removal and Installation
Procedure revision date: 04/1/2022
Transmission Fluid Pan, Gasket and Filter - 2.7L EcoBoost (238kW/324PS)/3.0L EcoBoost (299kW/406PS) (DD)
Materials
NameSpecification
Motorcraft® MERCON® ULV Automatic Transmission Fluid
XT-12-QULV
WSS-M2C949-A,
Removal
  1. With the vehicle in NEUTRAL, position it on a hoist.
    Refer to: Jacking and Lifting (100-02 Jacking and Lifting, Description and Operation).
  1. If equipped, remove the bolts and the rear skid plate.
  1. If equipped, remove the bolts and the skid plate.
Vehicles with Sway Bar Disconnect
  1. Disconnect the electrical connectors and the wiring harness retainers from the sway bar disconnect.
    1. Support the sway bar disconnect.
    1. Remove and discard the nuts and bolts.
  1. Allow the sway bar disconnect to lower.
All vehicles
  1. Remove the transmission fluid heat exchanger tube bracket bolt.
  1. Remove and discard the bolt and position aside the transmission fluid heat exchanger tubes.
  1. If equipped, remove the retainers and the LH and RH heatshields.
  1. If equipped, remove the RH and LH retainers and position aside the NVH cover.
  1. NOTE: Note the location of the bolts and studbolts for assembly.
    NOTE: Be prepared to collect escaping fluid.
    Remove the transmission fluid pan bolts and allow the transmission fluid to drain.
  1. NOTE: The transmission fluid pan gasket can be reused if not damaged.
    NOTE: Note the location of the alignment tabs.
    Remove the transmission fluid pan gasket.
  1. NOTE: The transmission fluid filter may be reused if no excessive contamination is indicated.
    NOTE: Note the location of the bolts for assembly.
    Remove the bolts and the transmission fluid filter.
    1. Short bolt 20 mm
    1. Long bolt 71 mm
  1. Clean and inspect the transmission fluid pan and magnets.
Installation
  1. NOTE: If the transmission is being repaired for a contamination-related failure, install a new transmission fluid filter and seal assembly. The transmission fluid filter may be reused if no excessive contamination is indicated.
    Inspect the transmission fluid filter seal. If necessary, replace the transmission fluid filter seal.
  1. Lubricate the transmission fluid filter seal with automatic transmission fluid.
    Material: Motorcraft® MERCON® ULV Automatic Transmission Fluid / XT-12-QULV (WSS-M2C949-A, )
  1. NOTICE: If the bolts are installed in the wrong locations, transmission damage will occur.
    NOTE:
    Install the filter and the bolts in the correct locations.
    1. Short bolt 20 mm
    1. Long bolt 71 mm
    • Torque: 93 lb.in (10.5 Nm)
    Align the tabs in the noted location and install the transmission fluid pan gasket.
  1. NOTE: Install the bolts and studbolts in the correct locations noted during removal.
    Loosely install the remaining bolts and studbolts.
    1. Tighten the studbolts in a crisscross pattern.
      Torque: 106 lb.in (12 Nm)
    1. Tighten the bolts in a crisscross pattern.
      Torque: 89 lb.in (10 Nm)
  1. If equipped, install the RH and LH NVH cover retainers.
  1. If equipped, install the LH and RH heatshields and the retainers.
    Torque: 80 lb.in (9 Nm)
  1. Inspect the transmission fluid heat exchanger O-ring seals and install new O-ring seals if necessary. Lubricate the O-ring seals.
  1. Connect the transmission fluid heat exchanger tubes and install the new bolt.
    Torque: 177 lb.in (20 Nm)
  1. Install the transmission fluid heat exchanger tube bracket bolt.
  1. Install the sway bar disconnect and the new nuts and bolts.
    Torque: 66 lb.ft (90 Nm)
  1. Connect the electrical connectors and the wiring harness retainers to the sway bar disconnect.
  1. If equipped, install the skid plate and the bolts.
    Torque: 22 lb.ft (30 Nm)
All vehicles
  1. Fill and check the transmission fluid.
    Refer to: Transmission Fluid Drain and Refill(307-01 Automatic Transmission - 10-Speed Automatic Transmission – 10R60, General Procedures).
  1. If equipped, install the rear skid plate and bolts.
    Torque: 35 lb.ft (48 Nm)
pakrat
JG
Lake Tahoe
Toyota 4Runner-F250-Tundra
2022 - 2023 Bronco
Materials
NameSpecification
XT-12-QULV
WSS-M2C949-A,
Removal
  2. If equipped, remove the bolts and the rear skid plate.
All vehicles
    1. Short bolt 20 mm
    1. Long bolt 71 mm
Installation
    NOTE:
    1. Short bolt 20 mm
    1. Long bolt 71 mm
All vehicles
  2. If equipped, install the rear skid plate and bolts.
Perfect. Thank you big time!
Rockdawg84
Sam
Tucson, AZ
98 4RUNNER, 96 F350 CC 4x4
thank you for the information. I will be getting the PPE pan and doing this swap. I'm at 40k miles and want to change the fluid and be able to do so on a more regular basis.
CarbonSteel
Colorado Springs
2023 Carbonized Gray
CarbonSteel
Colorado Springs
Here are the torque specs and the torque sequence from PPE:
https://cdn.shopify.com/s/files/1/0611/8539/2883/files/328053200_Install_Guide_v4.pdf?v=1659458504
CarbonSteel
Colorado Springs
If anyone is interested, I have a NIB deep Mishimoto pan for sale on the forum. Received a PPE pan for Christmas after buying a Mishimoto.
  • Like
Reactions: 0ne
pakrat
JG
Lake Tahoe
I finally did mine a few weeks back. Word to the wise this is fairly messy even if you vacuum out everything in the pan prior to dropping in completely. Also, the proper tools go along way in filling it back up, checking level, adding more, or removing some as needed. The filter probably didn't need changing but as long as your going through the hassle it is an easy additional step. It is not that bad but does require more patience and attention to detail than an oil change.
FYI, I did it 28K. Was not much on the magnet but definitely some break-in wear for sure. Also did a sort of poor man's flush and before dropping the pan I sucked out almost 6 qts. of fluid, replaced it, drove it to get it to temp and circulate the new fluid, and then drained it again and replaced the pan and filter. That way I knew I had nearly all fresh fluid in there. Cost a little extra but I'm only doing that once after break-in. My plan is +/- every 4th oil change to dump and pump new fluid depending on my driving conditions.
swamp2
Needs be at operating temperature (206-215) running in park to check it correctly.
Level on the dipstick should be between the 3 and 4
Hi. Is the fill level identical in the Raptor? Thanks.
CarbonSteel
Colorado Springs
@Ducati1098 - is the removal of the transmission fluid heat exchanger tubes necessary because they are in the way of the pan bolts or?
Ducati1098
Kind of both. Since the exhaust is underneath the rear of the pan, the lines get in the way of moving the pan forward and down. But they also may be blocking a few of the bolts. They don’t need to be removed completely, just slightly adjusted out of the way.
CarbonSteel
Colorado Springs
Ah, so no need to worry about replacing the o-rings because you do not detach the lines? Just want to be sure in case I need to order some.
kr_1315
kr_1315
Kevin
Houston, TX
F150, Tundra, Explorer, IS500, '23 Bronco 2DR
Correct. No need to replace the O-rings. I have over 10,000 miles since the pan installation and no leaks.
Ducati1098
No, they’re completely reusable. You do detach the lines, but they just get popped out of the side of the case and the lines moved aside.
If for some reason you’d like to replace them, or if they potentially get damaged, the part number is 7L1Z-7J227-A, but I’ve never replaced a single set or had an issue reusing them.
CarbonSteel
Colorado Springs
But did you remove the lines from the transmission?
