Oil type
moniarafaleric
Ralph
New York
Subaru Forester, Ford Bronco
Hello everyone, just wondering if we are running the Motorcraft synthetic blend or the Motorcraft full synthetic in our bronco raptors? I’m about to do my first oil change and wondering what you guys are using?
Thanks
Pennzoil ultra platinum on my Explorer ST and 2.7 Bronco, will not use anything else
RimrockPaul
Paul
Rimrock AZ
2021 Ford F250
Thanks
Really? Another oil thread? I use mobil 1 oil and filters. Same as I use on my Tacoma.
Fordified1
Bob
Mid South Texas
Full synthetic. Any name brand. Less likely to turn to carbon from turbo heat, flows better on extremely cold startups. Maintains viscosity at extreme temperatures.
I use Amsoil.
jdbabb4247
Wernersville, PA
2022 Ford Bronco OBX
Either of Ford's oil is fine. Full Syn has properties that are better especially for longer runs between changes. Any oil that meets Ford's specs for oil will be fine. Actually any API SP rated oil will be just fine.
All the above is true if you change your oil and filter when it is time to change it. I use an SP rated oil and change around every 5,000 miles. We could go farther but we live on a dirt road.
Change mine every 3500 faithfully.
Callelk
Larry
Idaho
Escalade ESV, Cherokee 2-Door
Pennzoil Platinum in the engine and I will switch to Amsoil for all the running gear once I hit 10K. Since I'm changing running gear every 3K I'm just using Mobile Gear oil in the diff's and Pennzoil in the T-Case for now. I have and still use Quaker State in my Escalade and have been very happy with it but decided to switch it up for the Bronc.
22 Spyder
Fort Lauderdale
2024 Azure Bronco Raptor (DD),2022 Porsche 718 Spyder(weekend)
I've been a fan of Royal Purple for the last few years in my Rubicon. Anybody using that oil?
ju015dd
coy
fl
2024 shelter green BRaptor
This is going in at 1k for my first oil change. Gonna run either mobile 1 or something similar.
Ford Bronco Oil type 1000004153
swamp2
Very cool mod. No mods needed for clearance? Are the metal canisters definitively better than factory?
Is this claim from Baxter valid,
"Provides faster oil pressure at startup by keeping the upper oil system flooded."
Johnkn
Maryland
'66 GT350, 68.5 CJ Mustang, B2, Viper, Pantera,TRX
Probably, It has an anti-drain back valve to keep the filter full at shutdown. The small valve shown is to drain the filter prior to changing.
swamp2
And the factory system does not? TIA.
swamp2
Do you change your own oil? It does not.
Thanks. No, why? I already bring my own oil AND filter when I get it changes.
