Oil capacity dipstick gate
LMG
Tupelo, MS
2024 Bronco Raptor 2026 F450
How many QTs of oil are you guys using to fill your 3.0 raptor bronco motor?
I searched and tons of threads relating to the 2.7 engine oil cap and dipstick gate.
Haven’t run across any discussing the Raptor motor.
Did my first oil change last night and a little confused as to what I put in and where it’s reading on the dipstick.
I also own a 21 f450 so I’m well aware of dipstick gate there as well.
Ducati1098
Whatever your owners manual says. Which should be 7 quarts
LMG
LMG
Tupelo, MS
Thanks. My manual says 7 if I recall. I added 7.5 and after sitting overnight and cold checking I’m halfway up the hash marks.
Nibroc99
Corbin
Rochester, MA, USA
www.corbonthecob.com
2022 Wildtrak: The WildeBeast
The owner's manual online says 6qts, but the one in the car says 7qts... Have we gotten this figured out yet?
Ducati1098
Well this was posted in the Raptor section, so which one are you asking about? Raptor or 2.7?
Nibroc99
Corbin
Rochester, MA, USA
Ah didn't notice that. I'm talking about the 2.7. I thought all 3 engines had the same issue though, didn't they?
Ducati1098
There was confusion for the 2.7 for a little while when it first came out, but the owners manual was corrected shortly after.
21-24 2.3 is 6 quarts
2025 2.3 is 5.6 quarts
2.7 is 6 quarts
3.0 is 7 quarts
cowman
cowman
texas
ford
I have been running 7 quarts in my 2021 2.7 since day one... no problems and it has never been back to the dealership for anything.... do my own oil changes...
Ducati1098
Same, except I've been running 6 quarts.
I think that goes to show there's no reason to use an extra quart for no reason.
cowman
cowman
texas
ford
Can you give a reason why they run 4 gals. of oil in a 140 hp tractor and recommend a oil change every 800 hrs in the diesel tractor? I can...
Ducati1098
Why don't they use 6 gals instead? lol
That literally has zero relevance here
cowman
cowman
texas
ford
They use 4 gal.... longer between oil changes ... more oil... less break down of the oil...
Ducati1098
Like I said, completely irrelevant in this case, but I’ll play along.
If more oil is better, why don’t they use 6 gallons or 8? Maybe 24? You’re just trying to justify something that is unnecessary. But you do you.
The spec for the 2.7 is 6 quarts. You use as many as you’d like lol
cowman
cowman
texas
ford
The spec is 6 quarts. Use as many as you’d like lol
Some do use that amount and oil change time increases.....
