Jack recommendation for Bronco Raptor
vrtical
Doug AI
GSMNP, TN
Fords
I use a 2-ton Gortech scissor jack. It comes with a height extension and does a great job For my Braptor On 37’s.
Gortech Scissor Jack
Here’s a video review that’s a little lengthy, but gets in to why this jack is so good.
The Gortech USA Heavy Duty Scissor Jack Review
(Sorry, don’t know how to embed YT vids here.)
UIsing a scissor jack on a braptor is not effective IMO with how much height you have to use to unload the suspension just to get the tire off the ground. The factory OEM setup comes the same way with extensions. You are better off putting that jack in a better much lower location.
5POINT56
2024 Bronco Raptor
Neither photo is of my Raptor. My understanding is that the OEM jack, using the riser, elevates to 19.5”. The Gortech jack raises it to 24”. It’s vastly more robust, stable and well built.
I really just wanted a taller, much better built, more stable version of what the Raptor comes with and to that end, it delivers 100%.
I’m guessing the OEM jack isn’t able to do this (not that i need it to, but kinda illustrates the point).
Ford Bronco Jack recommendation for Bronco Raptor IMG_8251
crenca
Southern New Mexico
Neither photo is of my Raptor. My understanding is that the OEM jack, using the riser, elevates to 19.5”. The Gortech jack raises higher than that. It’s vastly more robust, stable and well built.
I also don't see (perhaps someone can explain)why a scissor jack is inherently any worse (or better) then a bottle jack with extensions in a high lift (say > 18 inches) situation. It seems to me either is dependent upon the execution (quality of materials, tolerances, stability of base, consciousness of the user, etc.).
swamp2
You are correct. It's just that most scissors have larger bases and top plates. So they are empirically better not inherently better.
BodieMonster
BodieMonster
Bay Area, California
Civic Type R, VW Atlas
If you or anyone knows of a similar, compact, hydraulic, bottle jack, of better origin or quality, I'd love to know about it.
Let us know your choice.
Will do! It's one of those things you hope you don't have to use much if at all on the trail so it's a bummer to spend a ton of money on one but when you do need it...
Given 21 inches should be sufficient, I'm leaning towards the PowerBuilt.
swamp2
Not to beat a dead horse, but the very compact jack I've been referring to (Torin) is plenty SUFFICIENT to do a basic tire change in the field. Less than 11" total max extended height and about 4" of stroke (I don't count adjustable height toward stroke)!
If you stick to traditional jack points MUCH more jack will be needed.
Regardless, a jack that is max height (or stroke) of 21" is wasaaaay more than needed.
Ford Bronco Jack recommendation for Bronco Raptor Screenshot_20251015-203600
justzukies
Justus
Grand Junction, Colorado, 81503
2023 Bronco Big Bend 4cyl w/Sasquatch, 2007 Nissan Frontier V6 w/lift
That Gortech and kit looks like a one and done to me. I might have to round one of those up.
TruckCamper
Peter
Kingman AZ
2023 Bronco 2Dr - 2022 Bronco Raptor
We just use the factory jack and a block of wood. Wood is great for not slipping and allowing various spacer heights. Only used it a couple times in two years. No way would I give up cargo space or capacity for most jacks. Hydraulic jacks are great until they leak out everywhere.
JohnGalt
Tahoe, CA
2023 Defender 110
I’ve been using a Power Mountain TallBoy and a jack pad lately. It’s got a large stable base, attachments to get enough height safely for when the logical jack point isn’t available. packs compactly and rattle free. Doesn’t weigh a whole lot more than OEM. Currently $130.
fate has a way of taking the logical option away from you on trail. the ridiculous amount of flexibility makes the jack/attachments useful for other projects as well.
https://www.tractorsupply.com/tsc/product/bulldog-winch-tallboy-off-road-jack-15-pc-2474253
monsterfd
2014 raptor widebody 37s, 2018 raptor 2018 JKU 35s
i have the sergant kit and love it. its the most complete kit for the size it packs. easy to move in and out. but you have to be mindful of your jack points and know how to get creative with the attachments. i use it on the axle or control arms up front.
MDrums
Tampa
Bronco Raptor
Im thinking this might be best for me. I have jacks in my garage but this Jack and stand combo looks good to put in back for long road trips with no wheeling or a day trips where I go offroad….. thoughts/opinions?
Ford Bronco Jack recommendation for Bronco Raptor IMG_2399
JohnGalt
Tahoe, CA
2023 Defender 110
@MDrums first pic… its about 11.75” to the shock mount on the LCA and 14” gets me about an inch off the ground. Note I have 38” tires (3/4” higher than stock) and 2” spring lift ( may give some small advantage while raising). So theoretically that jack will work on this point. The jack does need to be very close to the tire, esp without the flat top
second pic it was about 17” to the LCA here, raised to about 20.5” to get an inch of clearance. Theoretically this will work, but you need a saddle to get safe contact. Also having a jack pad like in the pic should keep you from getting to the end of your stroke.
Ford Bronco Jack recommendation for Bronco Raptor IMG_5155
Ford Bronco Jack recommendation for Bronco Raptor IMG_5154
