Diesel Bronco Raptor
CR_IN_UT
CR_IN_UT
St. George, UT
F150 Shelby Raptor, Bronco Raptor, Jeep 392, 05 LJ
The tech got the oil hoses mixed up and filled it with transmission fluid or something thin and dumb. Viscosity is a little higher at first startup but gets way too thin when it warms up, thus the noises. That’s the only thing that makes sense. Unless he screwed up and started it without oil by accident and it clearances the bearings for you. It really sounds like low oil pressure noises. Your oil pressure gauge is really only an idiot light. It reads has pressure or doesn’t. Nothing in between really.
This is interesting. I never thought about it stemming from the oil change!
mpeugeot
That motor is f'd for sure. Tech said it was fine? Find another tech.
I bet that the OBD2 port can give you the information you need to figure out what is going on.
CR_IN_UT
CR_IN_UT
St. George, UT
Thanks for responding!
OBD2 shows nothing stored. I checked it with a reader. No CEL either.
Why would the CATS melt in the first place? And that happened prior to the noise. The whole thing is nuts.
mpeugeot
You should be able to read oil pressure on OBD2. Look at the timing advance etc... There's going to be a sensor somewhere showing something up.
If all else fails, pull the plugs and scope the bores. It would not hurt to get an oil sample and have it analyzed.
Kevin Scarbel
Everglades
Kevin
Chesapeake, VA
2024 Bronco Everglades 4dr
Everglades
I'd be thrilled to own a 3.2L diesel-powered Bronco (or at least a 2.0L EcoBlue diesel).
351W-Bronco
Herb
Southern New Mexico
2023 Bronco,1969 Bronco, 2001 Excursion (7.3L)
Maybe get an oil sample and send it to Blackstone for analysis. Always good to have data and not just opinions.
Herb
BroncoB
Christine
Tampa Fl
Bronco First Edition
That's what I was wondering. I had 2 sets of cats warrantied on my F150 2.7l before 60k miles and they have no idea why.
mpeugeot
Excessive egts would be the only thing that would cause the converters to melt down (but the cause of the excessive egts can be numerous).
swamp2
Are you sure? My Raptor has the precise, real time oil pressure available on the dash.
CarGuy
New Jersey
2023 Ford Bronco
Hard to diagnose from a video, but sounds like a rod bearing. Oil filter should be checked for metal.
Fordified1
Bob
Mid South Texas
I admit I’m not familiar with the Braptor. It gives a varying actual psi reading? The way to tell is oil PSI will increase and decrease with rpm. Same with temperature, oil pressure will read high at cold startup and decrease at idle as it warms up.
Fordified1
Bob
Mid South Texas
It went in the shop sounding fine and came out sounding like it’s making metal. All they supposedly did was change catalytic converters and do an oil change. Only thing that makes sense is it’s somehow oil change related.
HeliPilot
Kenny
CT
2022 2.7L SAS
Yeah, and they will drain/flush/refill and call it good. And it may sound good, but I’d suspect the longevity of the engine to be diminished. I wouldn’t accept it back without some long extended warranty.
Cux211
NE PA
19 ram 2500 Laramie blackout cummins
Sounds exactly what my 2.7 sounded like it’s at the dealer now getting the engine torn apart to do cam phasers only thing is mine would only do it for the first 5seconds or so at start up yours sounds like it stays like that
Cux211
NE PA
Melting cats is a typical problem
With boosted engines generally in stock form there’s usually no problem you may have just got defective cats from the manufacturer
