Changing your own oil?
Hoofnmouth
mark
N ca
ford focus st
Happened once in my life on a 94? Cherokee. First car I bought for my son and I worked with him to change the oil the first time and the old square profile o ring was stuck from the old filter and i put another on with the new filter. All zipped up, started the truck and after about a 15 second delay, "Ugh, Dad?" What a mess. should never happen again.
In every neighborhood in america there is a house on the block that has a squirt trail goin from driveway around the block and back you and your son are not alone. The old double o ring trick.
85_Ranger4x4
Iowa
1985 Ford Ranger
That’s the only way you’re getting that treatment with big 3 is if you’re either working within or you spent $500k+ on vehicles. So regardless. It’s moot because 90% won’t get that sort of treatment. Aka bragger lol
Small town, small dealer. It is kind of do a good job or die.
I think he runs a pretty good ship.
Austin26
Austin
Houston, Texas
2019 Subaru Crosstrek
I plan on using a pump on mine... Its proven to do just as good a job. Some engines don't even have drain plugs anymore. I use a 12volt version made for marine engines. Don't even need to get on the ground.
I just went down a rabbit hole on oil extractors thinking I may have found an improvement. for the Ecoboosts i found it to be discouraged as it needs to drip for 20-30 minutes as there's oil somewhere tucked away that needs to get out due to the auto start stop feature. Perhaps if you sucked as much as you could and then waited a while to get some more would accomplish the same thing but I'd look into it.
Gotdesl
Alan
Rifle, CO
2016 Ram 3500 Megacab 4x4
I do my own services for multiple reasons, the least of which is saving money. That said, I do save money doing it myself. Driving a Cummins 6.7, I am dealing with a much larger volume of oil than a gas engine and I do use the best oil and filters that I can find. Tell your oil change place specific fluids and filters that you want used and see what that ticket is then.
Doing your own fluid changes will make you much more familiar with your vehicle, you will be more adept and comfortable doing your own larger services and repairs (real money savings), and I guarantee that you will care more in how something is done than anyone you could pay to do the work. I commend you for taking it upon yourself to learning new skills and being responsible for your own vehicle. What you gain from doing so is priceless.
orion
Jeremy
17' F-250, 17' Explorer
I always work on my own vehicles. I'll only ever take it back for warranty work.
Even then, I hesitate! I have a 2017 Super Duty, and right before the 3yr/36k warranty expired I noticed my rear pinion seal had a leak. I took it in and was expecting them just to fix the seal, nope! They did all of the recall work that I intentionally didn't want done, because I don't want people touching my cars if they don't have to. Well got it back and they performed the block heater recall and the seat belt tensioner recall. I thought to myself, great - what did they eff up??? So I checked the block heat, all good except the routing was not quite right and one of the tabs was not inserted into the frame for the wiring. Then I checked the seat belt tensioner area, both B-piller covers were scratched up like the were pulled of and just thrown on to the floor and slid. 🤬
Then, our Explorer started chiping paint on the hood. So we took it in, hesitantly again to get it fixed. Instead of repainting they needed to replace. ??? Anyways, the new hood came in, and was replaced at an autobody shop. Well, when we got it back, the hood lettering, EXPLORER, across the hood was jacked. The first E looked very crooked. Called dealer to let them know it needed to be redone. He agreed and ordered the new lettering kit. The body shop installed again, not to my satisfaction but it will be OK. Then, the we went to use the wipers for the first time since getting the new hood and guess what, not working like they're supposed to. Hmm, figures, just another reason I will try my hardest to never let anyone touch my stuff. Tried replacing the nozzles, nope. It needed the whole new hose assembly. Pulled the hood insulation off and started pulling the original hose off to replace. I think only one tab was still usable on that hose. The rest were broken like the just grabbed it and ripped it off instead of using patience and the right tool for the job!
Yep, not taking my stuff anywhere, even Ford, unless the motors blown.
RiverRat001
Jesse
Buffalo, NY
14 Fusion, 18 Grand Caravan, 78 F250, 81 CB750F
Remember: no one cares more about your Bronco than you do. Get the right tools, take your time, enjoy that peace of mind.
To echo @Tilzbow: start a physical file/journal. Keep receipts of your oil+filter, and record dates/mileages of your services. Warranty shouldn’t be an issue.
Always double check the fine print here though. Example: the owner’s manual states oil change interval is 5k-10k depending on type of driving. But the warranty may only be valid if you stay under 5k between changes. Usually this is only a factor for extended warranties though, not factory warranties
BEM-S4
Philadelphia
BMWs & Porsches
Also in play is how much a dealership is making from a given customer. Seeing as you take 5 cars to the BMW dealership for service, and you've used them for modifications, makes sense for them to treat you well.
A buddy of mine is a big spender at a dealership (including paying too much for cars because of his aversion to haggling). He told me the dealer loves him and family and treats them so good. Damn straight, if running that dealership, I would roll out the red carpet. :)
Yep. My only point in any of this was that the dealer isn't ALWAYS a ripoff or doing crap work. Good dealer service departments, if you can find them, are worth their weight in gold. Just makes everything so easy and you never need to worry about your warranty.
dcmdon
Don
Metro-West Boston
The hardest part, by far, is finding containers to store, transport, and find a legal place to dispose of the used oil (always seems to be extra oil in the pan from a lawnmower or something that won't go back in the empty new oil jug.
I stopped changing my own oil when I lost access to the lifts and disposal facilities at the dealership I used to work at.
Though I have to say that the top mount oil filter makes me think about doing it again.
I have used a fumoto valve ( fumotousa.com ) and trust them.
With a fumoto valve and top mount oil filter, it might be worth doing myself. Though where and how the drain plug is located will really determine that.
To be worth doing myself, the plug would need to be accessible without removing skid plates. To use a fumoto valve, the location would need to be protected.
ATHIKER
Bill
Toyota Corolla
AutoZone takes your used oil at no charge
FerkinBlonco
AK
2008 KLR 650, 2022 Bronco Base (2dr/7mt/CO)
This is my budding old man skepticism kicking in.... nobody is going to care more about doing a proper change than you are. Due to the reasonable prices that many places offer for changes, there is probably an incentive to get things done quick. Couple that with generally less experienced folk being willing to accept the pay that kind of job offers, and I don't think you can guarantee you always get the right level or oil grade.
Idk if this is why, or if it's just my luck, but the few times I've paid for a change it's been overfilled. To me, it's been plenty worth my time to do it, just for peace of mind. Plus, if you're waiting an hour in line anyway... might as well spend that hour dinking around and figuring out the change. As others have said, it's not too bad.
@Vigor, my advice to you - invest in an OK torque wrench so you tighten that pesky drain plug just right, RTFM for oil quantity and ratings, and if all else fails YouTube is your friend. And we are too 🍻
BadlandsBill
Bill
Flower Mound TX
86 Suzuki Samurai Modified, 2017 F-250 King Ranch
Man local Wally Worlds take old oil, they gladly except mine even mixed with trans and dif fluids. My son took his Mustang GT to quickly change type of place, they forgot to add oil, toast down the road, he had his stereo blasting didn’t hear starved engine. it still ran he added oil and traded it in. Change your own freakin oil if at all possible. Don’t be cheap, these Eco Boost’s must have full synthetic.
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
I have done my sons Ranger (2.3) and my F150 (2.7) They are both pretty easy. Just YouTube and take it slow and you are good to go. I do my own and almost always have. I use my choice of oil, good quality filters (usually OE) and know it’s done right (usually). Do it and enjoy! I always take my oil back to Advanced Auto parts or O’reilly, never had an issue.
The Bronze
Kelly
1986 Suzuki Samurai, 1967 Ford Bronco, 1993 Turbo Notchback, 2006 Sierra K1500, 2013 Sierra K1500, 2014 Sienna Mini-Van
Check out popular mechanics for useful tips on how to dispose of oil.
I had the Hot Rod article up on my wall for years. Much like yours, but they liked to use a tile to cover up the pit when not in use. Classy! :)
MayhemMike
Mercury
Buy your Motorcraft filters and oil from Walmart. They are the cheapest by far. You can even order the filters on line and have them shipped.
