Changing Oil Drain Plug on 2.3L recommended?
2021FordBronco2
Jo
Nampa, ID
2024 Ford Bronco Big Bend
I was wondering if Ford recommends that you change the oil drain plug on the 2.3 every oil change even though it isn't a plastic one.
I don't even think I have a washer on mine, but I probably should.
2021FordBronco2
2021FordBronco2
Jo
Nampa, ID
You should replace the crush washer on the bolt every oil change. I have never bothered, never had a leak out a threaded oil pan drain.
Ok so it is just a crush washer that needs to be replace, thank you! I couldn't seem to find this info anywhere as everyone kept saying you have to replace it because of the 2.7.
HotdogThud
mk6 gti, '21 MoarDoor
the 2.3 doesn't have a crush washer on it, it's a silicon grommet on the inside of the head of the bolt. So unless your dealership (*cough*San Tan Ford*cough*) is using impacts to take it on and off, you shouldn't have to replace it.
2021FordBronco2
2021FordBronco2
Jo
Nampa, ID
How many oil changes would you say when it would be time to replace it? Or is it just when the silicon grommet just is hard and brittle?
MayhemMike
Mercury
It is a permanent plug. Odds are that same plug will be still in the oil pan while the Bronco is in the scrap yard.
When you notice it starting to drip in your driveway/garage.
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
They do not recommend replacing it with every oil change in the service manual.
@HotdogThud already mentioned this, but it has an integrated gasket/washer. Just inspect it for wear/cracking/etc. and replace if necessary. My 2013 Focus has a similar drain plug (may actually be the same part), and I've only had to replace it once in the 10+ years I've owned that car.
2021FordBronco2
2021FordBronco2
Jo
Nampa, ID
Where is it located at in the owner's manual, I looked and couldn't find it. AKA I am blind.
RagnarKon
Bryan
New England
2021FordBronco2
2021FordBronco2
Jo
Nampa, ID
thesocalexplorer
Joe
Southern California
I haven't changed mine yet, 4 oil changes in & 25k miles. Every time I change my oil, I just give it a nice cleaning & check the integrated green silicone gasket for pliability. Might change the plug just for the hell of it in a few years, since the material will eventually degrade.
