Oil Drain Plug replace - at oil change....
BiggerBend
Kevin
East of Nashville
Bronco "Sport" BigBend, Fullsize 2 Door Bronco BigBend
Why.......?
I've seen several clips where people are changing the oil plug at an oil change interval.
This seems ridiculous if you clean and put back at the recommended torque.
Am I missing something????
adam1991
VW GTI (2)
plastic pan, plastic plug...it's like changing the oil before 10K. Cheap insurance.
Yes, my 2.7 pan and plug are plastic. If you're torquing it down, you're doing it wrong.
Hitemstiff
Tyler
Idaho
21 Badlands/ 05 Expedition/ 77 F150 Ranger SB 4x4
my plug never gets removed. Ford mobile service van sucks the oil out through the dipstick tube. If you got lifetime oil changes when you bought it, the mobile service option is included.
Kevin Scarbel
Everglades
Kevin
Chesapeake, VA
2024 Bronco Everglades 4dr
Everglades
Why.......?
I replace the drain plug once.........with a Fumoto F107SX drain valve (2.3L). Then, draining oil is easy peasy forever and ever.
VAtruck
Why.......?
The threads wear on oil pan plugs. I suspect plastic ones wear faster.
JP2
SoCal
Bronco 4 door
I just use a cork. If it's good enough for my wine it's good enough for my oil.
You may need some more wine when that cork falls out while you're on the highway and completely destroys your engine from lack of lubrication. The upside is you'll have more corks 🤷‍♂️
Johnkn
Maryland
'66 GT350, 68.5 CJ Mustang, B2, Viper, Pantera,TRX
You’ve never changed your oil on your Bronco or an Ecoboost motor with plastic pan, right?
There are no conventional threads, the plug is sealed with an O-ring and the ‘ears’ on the plug engage with the pan to secure it in place. See the UPR billet version in post #4.
klennop
Keith
Appleton, WI
24 Braptor, 04 S2000, 21 BMW R1250RS, 18 Mazda 6
For me it is more about the functionality/mess with the plastic drain plug. I will be replacing at the next oil change.
BroncoWTFAN
NJ
MachE FE & BL SAS 22
Lots of threads on this topic already but I replaced it during my second oil change. They are cheap anyway so why not each time. I’m not a fan of the aftermarket ones myself but many swear by them.
wjtinfwb
Bill
Destin FL
Jeep GC, Excursion, Focus ST, Subaru Crosstrek
I thought the same but then ordered a 3-pack on Amazon. They're indistinguishable from the Ford ones and only 8 bucks for a 3 pack. I replace the drain plug every 2nd oil change, my rationale is they're plastic and plastic becomes brittle with age and heat. Cheap insurance.
Ducati1098
Negative. The plastic ones don’t wear out at all. They aren’t typical threads.
The metal one on the 2.3 will never wear out as long as some lubie isn’t over tightening the crap out of it lol
adam1991
VW GTI (2)
Absolutely cheap insurance.
I thought everyone knew that about plastic.
