Oil Drain Plug replace - at oil change....
Greg2060
Greg
At the beach, NC
Chevy Silverado
Does anyone know the O-ring size for the plug? I've reused the original plug, but think I might want to replace the O-ring next time.
BigMeatsBronco
Allan
2021 FE 2 door
on our Ranger Raptor, the dealership tech did NOT tighten the plastic plug correctly, dumped 2-3 Quarts out all over the undercarriage and it got blown up and all over engine bay. Called them up with an attitude and told them to get this s*** fixed now, they sent out at mobile tech guy and he checked the oil and then towed the truck back to the dealership for the engine detail and a new oil change and a new plug.
They actually installed a new style of plug (Ford) that is quite a bit different than the older one. Similar to the aftermarket ones above. I find it odd that Ford would offer a replacement part but not tell anyone there's an issue with the original. Plastic drain pans and plugs are junk in my opinion.
adam1991
VW GTI (2)
They actually installed a new style of plug that is quite a bit different than the older one. Similar to the aftermarket ones above. I find it odd that Ford would offer a replacement part but not tell anyone there's an issue with the original.
yet another reason to get a new (and not expensive) plastic plug every time.
Langwilliams
Langley
Cleveland Ohio
2023 Bronco big bend, 2014 Harley Street Glide
I replace the drain plug once.........with a Fumoto F107SX drain valve (2.3L). Then, draining oil is easy peasy forever and ever.
I did this on my ranger an if I start doing my own changes on the bronco I will put one on it. I use the valve with the nipple for a drain hose. I leave the hose on the skid plate connected to the valve. I just put it in a jug an open the valve, no removing skid plates.
Kevin Scarbel
Everglades
Kevin
Chesapeake, VA
2024 Bronco Everglades 4dr
Everglades
True story. A Fumoto rep walked into my truck dealer in 1982 and introduced the Fumoto product to me. I was immediately sold on the design and quality. He set up an account for me on the spot. I immediately installed them on all my (Ford) parts delivery and service trucks, which I personally serviced monthly. What a time saver. I've been using them ever since. I even have one on my Yanmar diesel-powered Deere X750.
*I had Fumoto drain valves on my diesel 1985-1986 Ford Rangers (factory-installed with 2.3L Mitsubishi turbo diesel engines).
Ducati1098
Curious how they managed to screw up installing it. You just do a quarter/half twist and it locks into place.
Also I’ve haven’t seen any type of new style plug. If they replaced it with something other than the normal yellow plug, it definitely wasn’t from Ford.
Bronco Don
Don
Rialto, California
Tacoma 4x4
I have changed mine a couple of times, but it seems fine to me using the plug more than a few times, never had a leak and have changed oil 8 times now., every 5k Mobil 1 full synthetic for my baby.
Nibroc99
Corbin
Rochester, MA, USA
www.corbonthecob.com
2022 Wildtrak: The WildeBeast
I use this, put it in after the first oil cage, now just turn the knurl knob. I just slip a clear rubber tube on the end.
Do you know if the UPR one comes with replacement O-rings? I love the design of that and would wanna buy extras to have on hand - I'd probably replace the O-ring every 20-30k mi just as a preventative maintenance step.
je1279
Jared
Upstate NY
2025 Bronco Badlands Sasquatch
Did something specific make you choose this over the Ronin valve? I have the Fumoto on my '23 F150 5.0 and love it, but its not an option for the 2.7.
Baja Bronco
2Sun AZ
22 Ford Bronco, 20 Ford Raptor
Don’t remember, but I haven’t removed mine since installing at about 2500 miles. I’m now at 17000 or so. Hasn’t leaked. I change my oil around every 4K.
Baja Bronco
2Sun AZ
Did something specific make you choose this over the Ronin valve. I have the Fumoto on my '23 F150 5.0 and love it, but its not an option for the 2.7.
Yeah, I wanted the Fumoto too, have it on my F150 Raptor. Nothing specific, I believe I had a $10 coupon at the time, LOL!
GroovyGeek
Boyan
'23 Bronco BD
Ronin all the way for me. Changed oil this weekend. Literally 5 minutes from go till start of drain. No mess no fuss. Waiting for the drip to stop took the longest.
adam1991
VW GTI (2)
If you have a drip that lasts longer than 4 hours, see a doctor.
VirginiaHeritage
Frank
‘25 Bronco HE
