Changing oil on 2025 Bronco with updated 2.3 engine - lessons learned
Wardog
New Jersey
2025 Bronco
Hello all, just wanted to put this out there to save everyone a potential future headache that I went through today.
Did the first oil change on my 2025 Bronco - base model with the updated 2.3 engine, which set the record for the longest oil change ever, at over 3 hours. Now note, I am not a rookie at this - I’ve changed the oil on many cars - Saturn Ion, Nissan Armada, Toyota Camry, my previous daily driver (a 2012 Hyundai Sonata) which was a piece of cake, probably as easy as oil changes get.
The oil change on this car is different, and not in a good way. It seems as if it was made to be intentionally difficult. However, it was made worse by the fact that this is the first year for the updated 2.3 engine, so previous videos and information weren’t exactly helpful. I’ll explain why below.
The oil drain bolt is relatively simple, very similar to old 2.3 Broncos. At least for the base model and those with the plastic shield, remove six 15 mm bolts, then conveniently, use the same 15mm ratchet to remove the drain bolt.
Now, the oil filter is a completely different story. Not seriously, but figuratively - I want to strangle the engineer who thought of the brilliant idea to put it where it resides. Previous videos and information recommend going through the driver side wheel well with a cap wrench and socket extensions. I have no idea how people did this. Maybe it is different for 2025, but there was absolutely no room to get in there. And I looked at it for a good 30 minutes. Did I mention that the plastic screw rivet holding the wheel well is a PITA to remove? That sucker is so easy to strip because it just refuses to come off.
Plan B that worked for me was using a squeeze/adjustable oil filter wrench, reaching deep in there. I was roughly positioned under the driver seat. I was able to do it as I am tall with long arms, but it is quite awkward. But it works.
Then, after FINALLY getting the oil filter off, a new problem arose: the new oil filter didn’t fit. I’m a Mobil 1 guy and their site told me M1-102A is what fit, so that’s what I got. Turns out, it does NOT fit, despite what they say. Upon closer inspection, the OEM filter (FL-2127) for the updated 2.3 Bronco has a slightly larger oil filter thread than the M1-102A.
So, in the middle of the oil change, I find myself at my local Advance Auto Parts looking for a new oil filter. Turns out there’s two oil filter thread sizes for the updated 2.3 - 22mm and 3/4 inch. At least from what the guy has in the system. I suspect the 3/4 inch is a remnant of the old 2.3, because the 22 mm oil filter thread is what is needed to fit the updated 2.3 Bronco. Even though I am a Mobil 1 guy, I got a Carquest Extended Performance filter, which advertises high flow and has filtration efficiency of 99.5% at 25 microns - not bad! (assuming the high flow is true) I may use this CQ filter moving forward, given it’s the only filter I know that is guaranteed to fit (aside from OEM, which I don’t want to use d/t the low filtration rating).
Thankfully the new oil filter fit and all was right in the world. No further snags - be sure to use the flat foot crank feature to prevent a dry start. Fully depressed accelerator + fully depressed clutch and then press the stop/start button.
TL;DR
So it seems, at least based on my experience today, you CANNOT go through the wheel well to remove the oil filter on the updated 2.3 ecoboost for the Bronco. Also, make sure your oil filter has a 22 mm thread, NOT 3/4 inch, or it won’t fit and you’ll be running to the auto parts store like me today. For those who want to know, the Carquest oil filter I mentioned previously has an identification code of P95140. 16 bucks or so which is quite steep for a filter but I needed it urgently.
All the best to everyone changing their oil on the updated 2.3 Broncos. Hopefully, this information will make yours go much faster, smoother, and with a lower blood pressure than mine.
GToddC5
Todd
South Jersey
www.bronco6g.com
I have a '21 and never entertained the wheel well option nonsense and have always gone at it from underneath without even jacking it up 🤷🏼‍♂️
Wardog
New Jersey
2025 Bronco
Basically what I did. So maybe the inability to remove the oil filter from the wheel well isn't exclusive to the 2025 with the updated 2.3. I had seen people doing it on 21-24 Broncos, but I looked at mine and there was absolutely no room to get a cap wrench in there.
Squatch
Wheel well is great. Turn the wheel all the way to the right before doing it, use a long extension from Hobo Freight and their cap wrench... too easy.
GToddC5
Todd
South Jersey
www.bronco6g.com
I figure I'm under there anyway to catch the flume ride oil into a tray so . . . 😂
I bought a fancy valve for the pan once but haven't installed it because I forget what hose is needed. A member here bought a bunch of it and offered it up but I never followed through on getting some 😛
kodiakisland
Arkansas
Nonsense? I can see my filter through the wheelwell. All I have to do is reach in and remove it. It's not that difficult. About as easy as it gets. Maybe we got different vehicles.
GToddC5
Todd
South Jersey
www.bronco6g.com
No you're probably right as I have the utmost respect for your shared experiences. It just seemed like I had to be under there anyway and was never a big deal for me to reach it to remove and install from underneath. I felt like the wheel well would be an extra step.
Squatch
Yeah... some member did buy about 25ft of the stuff and now he can catch the oil flume ride with the pan while the Tygon tubing redirects oil from the valve into the same catch pan. :wink:
I bet, if you asked nicely, that member would still hook you up with some of the tubing. 😁
Keith J.
2024 Bronco
I have no issue removing my oil filter from the wheel well with extensions and a cap style removal tool. My issue comes in with the install of the new filter. Being that I have a decently aggressive offset on the aftermarket wheels, I cannot get enough of a good reach upon install. Instead, I've found it quite easy to go from the top and snake it in that way. 15 minutes start to finish.
kodiakisland
Arkansas
I use the 400S filter which I think is a little longer than the OEM filter. That may help quite a bit from the side.
GToddC5
Todd
South Jersey
www.bronco6g.com
I always order the MOTUL 8100 kit from IAG that comes with the OEM filter.
Kevin Scarbel
Everglades
Kevin
Chesapeake, VA
2024 Bronco Everglades 4dr
Everglades
TL;DR
Why not purchase the FL-2127 from Ford? Plenty of Ford dealers sell them at wholesale pricing.
I always change the oil when I do the tire rotation, and with the tire off it’s pretty easy to get at the filter
itwelder
Lee
SoCal
BaseSquatch 2DR
I honestly don't understand the fuss. And why everyone is making their life harder by going in the wheel well, or under the vehicle. I changed mine last week (25 Badlands) and literally just reached down in the engine compartment, like any other car. Used a cap-style filter wrench, and regular ratched, and removed the filter. The whole process took maybe 15 minutes, less cleanup.
Now, my Badlands is non-SAS and on OEM 33s, so it's fairly low. On my slightly higher Basesquatch, I did use the first rung of a small step ladder, but same thing - just reach down and unscrew the filter. There's tons of room in the 2.3 engine compartment, or am I missing something here?
CitrusBronco
Everglades
Citrus county, FL
Everglades
Sharp knife and cut out a bit of the wheel well liner to make access easier worked for me.
